Can someone show me where the A/C actuator is located or how to replace it?
Old Sep 26, 2015 | 05:22 PM
master111's Avatar
Hi
Can someone show me a diagram or photos on where to find the (Air Conditioning actuator) on an 07 G35 coupe? It would be useful to share how to replace it.
Thank you guys!
Old Sep 27, 2015 | 07:10 PM
wuzz-upp's Avatar
Originally Posted by master111
Hi
Thank you guys!
Exactly what is this actuator you are looking for suppose to actuate?
Old Sep 27, 2015 | 08:15 PM
master111's Avatar
It is a part that change the air flow from top vents, defrost, to floor vents while pressing on the A/C mode.
Old Sep 27, 2015 | 08:50 PM
wuzz-upp's Avatar
Attached is the section of the service manual that shows the Mode Door Motor and the Air Mix Door Motors.
Attached Thumbnails Can someone show me where the A/C actuator is located or how to replace it?-capture.png
Old Sep 28, 2015 | 02:11 AM
JOKER's Avatar
CLUB MODERATOR
it's located in the middle under the dash on a heater condense thingy
http://www.infinitipartsonline.com/i..._name=actuator
I've got a used one off of a 2004 G Coupe I'm parting out.
Old Sep 28, 2015 | 08:51 AM
wuzz-upp's Avatar
Originally Posted by JOKER
it's located in the idle under the dash on a heater condense thingy
You might have a buyer for that part . What exterior color is that 2004 you are parting out?
Old Oct 5, 2015 | 09:54 PM
JOKER's Avatar
CLUB MODERATOR
Diamond graphite.
Old Oct 5, 2015 | 10:04 PM
JOKER's Avatar
CLUB MODERATOR
You AC actuator thing is going to be the easiest to replace. It's located on a blower motor housing on the right side and can be accessed after glove box is removed. (you might have to remove the blower motor housing which is held by 3 screws if you are unable to get a screw driver in there and take out the screws for AC actuator.
Something like this may help you get to the screws without taking out the blower motor housing.
http://www.homedepot.com/p/DEWALT-Ri...RA50/203867866
Old Oct 6, 2015 | 01:36 AM
master111's Avatar
I was able to take out the blower motor without removing the glove box. You just need to remove the part (cover) that goes underneath the glove box, and it's accessible to remove the blower motor from there, but I am not sure if I can replace the A/C actuator that way without removing the glove box? Do you have any idea?
xluke
Jul 30, 2016 01:48 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Rehman2009
Jul 27, 2015 03:23 AM
