Got Rims Earlier Than I Expected (NO 56k)
Old Jul 26, 2008 | 02:53 PM
The Stimulation's Avatar
Originally I was going to wait on buying some rims, but I got a good deal on these primarily because I mainly traded car audio stuff I don't even use anymore. They aren't my first rim choice, but I do like them. Originally I intended to go 19's or 20's (leaning toward 19's since I'm going to lower the car in the future).
These are 20" MOZ Tower 5 black rims with a chrome dish and lip. Lighting wasn't the greatest so I'll take more pics with better lighting later and even get some rolling shots. Enough talk, time for the show. I really like how easy these things are to clean
Close-up of rims:
Old Jul 26, 2008 | 03:00 PM
suicidesam's Avatar
****defected****
are you using black tape for tires?
Old Jul 26, 2008 | 03:02 PM
Gitsum's Avatar
WOW! Those rim edges are out there...I see lots of swerving in your future...
Old Jul 26, 2008 | 03:03 PM
CandlestickPark's Avatar
ill Sedan
What size tires are you running? What are your plans for a drop, will make a big difference.
Old Jul 26, 2008 | 03:05 PM
EL-EE-ES's Avatar
1st thing that came to my mind when i saw that...looks good
Old Jul 26, 2008 | 04:54 PM
Tire size is 225/30ZR/20
I would have wanted them to be bigger and wider, but there is still PLENTY of tread remaining. Down the line I'll go ahead and get wider and larger profile tirse.
Old Jul 26, 2008 | 04:56 PM
Plans for dropping are undecided now, not sure exactly how many inches. It won't be for a while though. I may go with Megan Racing Coilovers or Tein Basics and when I do, I may downgrade to 19's and get something with a 3 or 4" lip.
Old Jul 26, 2008 | 05:07 PM
Joaquin03's Avatar
Staff ALUMNI
if you stick with these, I would definitely suggest you lower it... also, don't expect those tires to last long...
Old Jul 26, 2008 | 05:33 PM
I don't, they are very thin for my taste, they look nice, but I like a bit more protection for my wheels. I will most definitely lower it regardless of staying with these or going with others. I just don't know which coil over kit to go with. I think the stock suspension is pretty good and I don't want to lose the quality, if it stays the same, thats fine, but as long as it doesnt get any worse.
Old Jul 26, 2008 | 08:07 PM
Triple8Sol's Avatar
Don't like them. Upsized aftermarket wheels with no drop warrants an immediate fail.
Old Jul 26, 2008 | 08:12 PM
reconJDM's Avatar
be very careful with manholes in a city near you.
definitely give your ride a drop and switch up the tire profile.
Old Jul 27, 2008 | 12:49 AM
I'm seeking to get it dropped shortly, might even do it within a couple weeks. I might try to sell the rims locally and get some 19's with bigger tires. That is originally what I wanted to do, but I couldn't pass up on the deal.
Old Jul 27, 2008 | 04:09 AM
zt967's Avatar
A good deal doesent mean you should go for it
Like everyone said, those tires are wayyy too small, almost dangerously small. The wheels actually make your car look cheap. Kudos to what everyone said about a drop. For what you paid for those wheels + tires, you probably could've got a set of Tein Basics. That + stock wheels would look better than those dubs you have now.
Old Jul 29, 2008 | 02:08 AM
az1anbeethoven's Avatar
Old Jul 29, 2008 | 02:23 AM
BlueDevilBAMF's Avatar
Wow those tires have a crazy small sidewall...
