Installed my spacers..
Old Mar 13, 2010 | 11:46 AM
  #46
jwolfpk's Avatar
thanks for the link i mite go with these because my spacers are ichiba v2 and there supposed to be a good brand...am i going to get alot of wear because clearance looks good since im not dropped or it doesnt matter?
Old Mar 13, 2010 | 11:52 AM
  #47
4DGS's Avatar
Ichiba is probably one of the best brands for spacers. I have V2s on my Z.
Old Mar 13, 2010 | 12:13 PM
  #48
TheTick's Avatar
I've noticed that people running spacers tend to need expensive bearing replacements after a while. I'm running 15mm all around and just started to hear that dreaded "wubba wubba" sound as well. I'm praying it's not the bearings.
Anyone here have any probs?
Old Mar 13, 2010 | 09:42 PM
  #49
brandon402's Avatar
Negative camber is negative camber, your tires WILL wear unevenly regardless of a drop as long as your camber is like that.
Old Mar 14, 2010 | 04:41 AM
  #50
ThickG's Avatar
So, if I have stock suspension and wheels and put spacers (20mm and 25mm) on, will I have to correct the negative camber?
Old Mar 14, 2010 | 06:04 AM
  #51
mjholla19's Avatar
YEA get an alignment first see if its adjustable if not then you might have to get a camber kit
Old Mar 14, 2010 | 08:19 AM
  #52
jwolfpk's Avatar
imo the negative camber looks sexy as hell
Old Mar 14, 2010 | 05:32 PM
  #53
mjholla19's Avatar
lol sexy but costly everybody know pretty girls are more expensive any camber can cause premature wear in tires and in this economy would you want that just for a lil sexy camber lol go ahead
Old Mar 14, 2010 | 08:50 PM
  #54
jwolfpk's Avatar
loll i think it shud be good get im just gonna get my tires rotated every once in a while i think it shud be fine..i do notice it kickin up alot of rocks though
Old Mar 14, 2010 | 10:16 PM
  #55
brandon402's Avatar
Yea, again, its not "bad" its just going to wear your tires out faster is all. If you can handle buying tires at a more accelerated rate than normal, then dont bother getting a camber kit.
Old Mar 14, 2010 | 11:58 PM
  #56
mjholla19's Avatar
and dont forget needing an alignment at an accelerated rate and a minor lose of handling and abnormal wear in suspension parts
Old Mar 15, 2010 | 08:18 AM
  #57
jwolfpk's Avatar
my car feels exactly the same and takes tighter turning
Old Mar 15, 2010 | 08:59 AM
  #58
mjholla19's Avatar
lol not now when suspension parts wear i lowered my car it was sweeet then i was way off in my alignment because i was being cheap and didnt buy a camber kit
Old Mar 15, 2010 | 09:28 AM
  #59
mao's Avatar
mao
Originally Posted by jayk
OP, put the 25mm in front sell those 20mm and put 30mm in the back!
Yes! i've been wanting to see how this set up would look. Has anybody done it and have pics to show?
Old Mar 15, 2010 | 07:23 PM
  #60
ConradoR's Avatar
So if I run 20-25 I need a camber kit? I've never heard of that before, I mean its only 20,25mm, makes that much of a difference?
I plan on running spacers for maybe 2,3 months before I upgrade wheels, do I still need a rear camber kit?
thanks
