Jfdeltoro's build-up
Old May 25, 2010 | 10:20 AM
Derek173's Avatar
Originally Posted by Jaydm24
I would have to disagree. I use my Navi all the time and it works just fine once you mute the voice command (annoying). Anyway car looks good I like the M6 wheels.
I use mine everyday too, and that fact that you have to use a joystick is awful and being DVD based makes it slow. Comparing the stock system with even my $100 Garmin its like comparing a Startec to an iPhone.
Old May 25, 2010 | 11:18 AM
jfdeltoro's Avatar
i opted to go with the oem mainly because of the physical looks, up & down feature. I may end up going with a double din later down the road and using oem screen as a secondary screen.
Old May 25, 2010 | 11:47 AM
XLR8_'s Avatar
Nice.....very nice that hella slammed! I guess street are not that bad in ur area
Old May 25, 2010 | 12:04 PM
Xet's Avatar
Xet
Nice work in such a short time, you gotta drive over some wooden blocks when you jack up your car next time, no more stuck jack! Not sure how I'm feeling the bmw wheels, looks too big but I might grow on it.
Old May 25, 2010 | 04:37 PM
Derek173's Avatar
I remember years ago when I took my G in to have the PAC adaptor installed, the installer kept saying how much he loved the fact that it goes up and down.
Much respect for being able to do the install yourself That made the mod cost effective so I guess I should shut up
I also had the PAC installer put a switch in so I can program on the move
Old May 26, 2010 | 01:35 AM
Z's G's Avatar
Rims look sick!!
Old May 26, 2010 | 07:14 AM
Jaydm24's Avatar
How did you get the M6 wheels to fit? I thought the lug pattern was 5x120 on the M?
Old May 26, 2010 | 07:50 AM
Integi2a00's Avatar
not my style to each his own
Old May 26, 2010 | 08:32 AM
av8or's Avatar
there are other functions of the oem nav other than telling you where to go... if your trunk is open and you drive off, the screen will prompt you... if you have your brakes on and drive, again it'll prompt you... you can set your mileage on how many miles before you will be reminded to change your oil and filter.. and most important, if there is any mulfunction on your car, it will again prompt you whats going on and the nav will direct you to the nearest "stealership"... to the op, good job on your oem nav install...
Old May 26, 2010 | 09:14 AM
lag35driver's Avatar
BMW
+ 1 on this question OP. Do you have to do anything to make it fit?
Old May 26, 2010 | 03:53 PM
VictoriousG's Avatar
M6 wheels ftmfw!!
Old May 27, 2010 | 02:57 AM
ptd23's Avatar
what coils are those?
Old May 27, 2010 | 11:43 AM
jfdeltoro's Avatar
To everyone asking about how to make them fit. you have to run adapters. The coilovers are stance GR+true coilovers.
Old May 27, 2010 | 04:48 PM
could you still put spacers on adapters?
Old May 27, 2010 | 10:35 PM
  #30
35Alive's Avatar
You can, but just because you can doesn't mean you should. Adds stress to something that's already adding stress on the studs.
