Hey guys, after waiting for about two weeks I finally installed my 350z H&R springs model 53050. They are supposed to drop the 350z 1.3f and 1.1r which means that they will drop the G 1.8f and 1.5r. I took measurements before I installed them and according to my measurements it dropped the front 1.5 and the rear .5. I'm a bit confused why it only dropped the rear .5 inches. The front should also be a little lower. I doubt the H&R springs will settle. I doubt I could have installed them upside down because I believe they only fit one way. Anyways if anyone knows any suggestions to this issue I would love to hear it. Here are the pics.
xXHotelCrazyXx
close
- Join DateApr 2007
- Locationfive oh two
iTrader Positive Feedback100
iTrader Feedback Score(21)
Liked:221 Times in 121 Posts
Give it some time all springs will settle over a couple weeks of good driving
Quote:
I hope so because I'm a bit unhappy with the rear.Originally Posted by xXHotelCrazyXx
BowWizzel
close
- Join DateApr 2012
- LocationSan Jose
iTrader Feedback Score(10)
Liked:96 Times in 85 Posts
Looking good. I think theres a diy on here where you cut down on the rear spring boot/rubber thing to get it lower in the rear.
Quote:
Thanks.Yeah, I know about that but the H&R springs that I used should lower the rear 1.5 without cutting the spring mount. According to my measurements it only lowered .5 . It lowers the Z 1.1 in the rear so something is weird here.Originally Posted by BowWizzel
Double check and make sure the spring is fully seated in the mount. As said above you can also cut the mount in half.
Th3R3dStar323
close
- Join DateNov 2010
- LocationGarland,TX
iTrader Feedback Score(4)
Liked:173 Times in 135 Posts
Or you can not run with the rubber mount at all like me!
Quote:
I'll have to take it apart and double check but I'm pretty sure everything is seated good in there. Mount is probably my next mod.Originally Posted by Massios
Quote:
Doesn't the spring move around in there without the mount? I mean there's really nothing in there that's holding it in place. Does it make any sounds on bumps of metal hitting against metal?Originally Posted by Th3R3dStar323
in on this thread, planning on buying springs as a first mod. Seems that these springs would provide a better drop in the rear so hopefully you find out its a simple fix.
Th3R3dStar323
close
- Join DateNov 2010
Quote:
It doesn't move around on me, and I don't notice any metal sound or any unusual sound from it either.Originally Posted by akogan79
Back in 05 when i first join g35driver, there was a local member in my area i forgot his name had the same set up as you. I clearly remember his car was slammed, I don't know dude but, something is not rite.
Quote:
sounds like a good drop but I wouldn't feel safe without that rubber thingy.Originally Posted by Th3R3dStar323
Quote:
I have seen pics of another g with the same springs and his rear was tucking, beats the heck out of me what could be wrong. Not really rocket science to throw those rear springs in. They just drop in there.Originally Posted by G35SHAWN
Th3R3dStar323
close
- Join DateNov 2010
345whp/338wtq and they are working just fine.......
Quote:
What springs are you running, have any pics?Originally Posted by Th3R3dStar323
