After the accident I made a commitment to do right to the G. I will never let her go, I'll build her up if she falls apart.
I attempted to recreate her with something with a sporty appearance but also something that looked like it could've been done from factory.
Details:
BMW A22 Sparkling Metallic Graphite
CF OEM Hood/K2 Trunk
K2 front
Nismo sides
CS Rear
I currently have some ebay lights on but you have no need to worry, I bought then to temporarily have them in place till I can find some reflectors I can retrofit. (yes I am looking but local only)
I bought a NWP Throttle Body and Motordyne 5/16 Plenum Spacer while this was all done.
I now have the mindset to build the engine, originally I was deadset on the Brian Crower stroker kit but recently changed my mind. I plan on doing a full rebuild kit from Z1 and grabbing some JWT C9 cams (may go with less aggressive C8 cams but still haven't decided.) Yes I will be doing a 11:1 compression ratio, no I do not want to go for crazy boost.
I also plan on doing a full swap to manual from the auto once the motor is completed.
