03/04 G35 Sedan Impul Front End from Klumzyee
Old Dec 11, 2007 | 11:52 AM
  #31
jonE5's Avatar
i like it, alot better than stock, but not as much as Nismo.
def more unique though
jon!
Old Dec 11, 2007 | 12:09 PM
  #32
clinthammer's Avatar
Originally Posted by ttrank
Thanks
I was going to wire them into the fog light switch and take the S2000 projectors off but for now they are on their own switch. I ran new wire with a relay and fused power from the battery. They are like driving lights right now, if the switch is on they come on/off with the ignition.
1. Where did you fix the new switch? Cuz I cant find a free slot inside the cabin.
2. I can get similar fog lights like you and have them mounted inside the lower grills. So all I would need is the light wiring, relay and anything else? Reason being, if I can get all the info, I can head over to a shop to have them installed and know what they are doing instead of going there clueless.
Thanks man and if if you have time, I think we all can use a new wallpaper like this:
Can you post a high res version of this:
Old Dec 11, 2007 | 12:22 PM
  #33
godmans's Avatar
Shhh Chico =)
I am already tempted to change up my front end to this..
but I don't want to do clear bra again lol... it would be my third clear bra for this car.
Old Dec 11, 2007 | 12:41 PM
  #34
g35freak86's Avatar
that looks effin insane!!!!! so jealous!!! awesome job tim!
Old Dec 11, 2007 | 12:57 PM
  #35
bert039's Avatar
SICK!!!
Old Dec 11, 2007 | 01:00 PM
  #36
bert039's Avatar
It looks like the front hangs down a lot more then the Nismo sides though. Do you have any side profile shots?
Old Dec 11, 2007 | 01:48 PM
  #37
ttrank's Avatar
Grocery getter
Originally Posted by Chico
that looks amazing Tim...I love the lines of the bumper...they compliment the car really well. Will Eric be making it for the '05 - '06 as well? That bumper will go amazing with the INGS sides he'll be working on.
Thank you.
I don't believe he has plans to make it for the 05/06 (as of now). He was talking about one like the Nismo but with wider side openings.
Old Dec 11, 2007 | 01:53 PM
  #38
ttrank's Avatar
Grocery getter
It is lower but not by much.
The only pics I have right now are before paint.
Old Dec 11, 2007 | 01:54 PM
  #39
ttrank's Avatar
Grocery getter
Originally Posted by godmans
Shhh Chico =)
This will be my third as well and this one will have to be custom made. They are enough of a PITA when it is cut for the car!
Old Dec 11, 2007 | 02:01 PM
  #40
ttrank's Avatar
Grocery getter
Since these will be on most of the time I just put the switch over in the top glove box. I have an aftermarket navi so that is open and where I keep my UTEC Tuner, Greddy boost controller, Tein EDFC and other switches like one to keep my halos on constant at shows.
Here is what I did.
The lights have a constant ground to them.
There is a fused power wire from the battery that goes to a Bosch 30A relay, pin 87.
Pin 86 goes through another small fuse to the ignition source on the motor. (on my car it is on the main harness that runs over the top of the timing cover)
Pin 85 goes to a switch (in the car) and then to ground to turn the relay on and off.
Pin 30 goes out to the positive on the fog lights.
It takes all of 20-30 minutes to do all the wires.
The other good place for a switch would be down by the trunk release. Do you have an open spot there?
I can't post high res pics on photobucket because of the size but if you want any I have them on my camera and can email to you if you PM me your email.
-Tim
Old Dec 11, 2007 | 02:44 PM
  #41
95 maxima se's Avatar
oh my god!!! one of the sexiest g-ride sedans in the planet! looking clean
Old Dec 11, 2007 | 02:55 PM
  #42
djkace77's Avatar
nice job tim...I can't wait to get mine
Old Dec 11, 2007 | 07:09 PM
  #43
ttrank's Avatar
Grocery getter
Yeah, you are going to love it.
Old Dec 11, 2007 | 07:30 PM
  #44
Philly_G35's Avatar
Looks great Tim. Can't wait to see better daytime pictures. Did you paint it yourself? It's probably cheaper to repaint it yourself every couple of years than doing a clear bra.
Old Dec 11, 2007 | 07:49 PM
  #45
JBaildon's Avatar
Now that looks great! One of a kind!
