TIRE_SMOKE TEASER PICS(not for 56k)
how did you know?!
Originally Posted by ttrank
Lookin good. Time for some larger brakes.
DAMN staggerd set up!
Originally Posted by VQ Hotness
Looking good.
The front could be a little bit lower..
Should look nice with an alinement.
perfect drop don't lower it any lower as for the spacers I wouldn't go over 5mm you are going to need some of that negative camber you have to keep from rubbing over speed bumps and the poor roads in general. Wait a couple weeks on the alignment to I waited a month just to be on the safe side.
Originally Posted by BlueDevilBAMF
Looks great... What do you think of the Silverstar Ultras? I was disappointed with mine
Finally! lol
Looks great Smoke. Big improvement over the stock height. Get the spacers....5mm should do the trick.
I hope you got my PM before you made your purchase today. If you run the spacers with the larger tire, it will most likely rub.
FS[NorEast]: New OEM G35x Compression Rods - Save!!
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
