Few shots with Brembo Brakes
Old Feb 26, 2009 | 12:50 AM
RickyGill's Avatar
looks great
Old Feb 26, 2009 | 01:11 PM
Tunerz_Store's Avatar
Originally Posted by MTG35guy
Looks good dude. Do you have both front and back?
Just the fronts for now. Plan on trying something different for the rears, I will post pics when its complete.
Originally Posted by Jeff92se
Looks hot! I assume you're running the stock MS. How is the pedal travel and what are your impressions on the braking? Stock brembo pads right?
Yes, stock master cylinder. The pedal travel seems about like it used to be, but the pads that came with the Brembo's were about half worn and my rears are pretty worn as well. So after I get the rear brakes on and some new Project MU pads on the fronts, then I can really compare the difference. I have done quite a bit of threshold braking and they will put you through the windshield if need be. I can tell you they dust just like the OEM floating setup too, which I can't stand and even more of a reason to get different pads.
Isn't the master cylinder the same for brembo and non-brembo cars?
Old Feb 26, 2009 | 01:19 PM
Jeff92se's Avatar
Red Card Crew
I don't know for 100%. On the Z forums, the MS is apparently divided into base/non-base. The non-base getting the larger one. ODD.
Here, I read the brembo equipped cars get the larger unit. But this is from memory.
I'm on 06 Z non brembos on my 03 sedan. I really like the performance and the pedal travel "might" have increased slightly. the nice feature of the 2 piston versions is that Infiniti put much less dusty pads as their oem fare.
Old Feb 26, 2009 | 01:41 PM
I had the 05 g coupe brakes which were two piston, was definitely a nice upgrade.
Old Feb 26, 2009 | 02:18 PM
MAXSE2KMT's Avatar
very nice. ill be installing mine saturday, f and r.
Old Feb 26, 2009 | 03:38 PM
your oem master cylinder or one from a brembo car?
Old Feb 26, 2009 | 05:00 PM
MAXSE2KMT's Avatar
oem
Old Feb 26, 2009 | 10:38 PM
04G35NYC's Avatar
hot, i want one also.
Old Feb 27, 2009 | 01:59 AM
reconJDM's Avatar
what a big differnce it made, looks very nice, I need brembos now :\.
Old Feb 27, 2009 | 04:53 AM
HenryLee's Avatar
realli like your sedan.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
nissandrifter32
Dec 22, 2015 04:28 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
alessandro
Oct 8, 2015 09:29 AM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
