The Process Begins....
Old Oct 30, 2010 | 12:56 PM
  #1486
naughty240's Avatar
^Just dont take my next color! haha
Old Oct 30, 2010 | 01:16 PM
  #1487
Heist.'s Avatar
oh what!? why would you change what you have it looks great!
Old Oct 30, 2010 | 08:16 PM
  #1488
NjMatteSedan's Avatar
heist look into the dark gray metallic on the new subarus. Amazing color! is a very dark gray with alot of flake to it
Old Oct 30, 2010 | 09:32 PM
  #1489
NFSP G35's Avatar
? = 2B || !2B
^Actually that is a tight color.
I would rather see Heist stick with the matte black. So few pull it off as he has. But yeah, a sedan in that Subaru color would be sweet.
Old Oct 30, 2010 | 09:40 PM
  #1490
NYYBaseball423's Avatar
This car gets abused with mods lol.
Old Nov 3, 2010 | 12:22 AM
  #1491
Heist.'s Avatar
Deciding on wheels has to be the most miserable ordeal hahaha. So indecisive.
Really leaning towards piano black or throwing on another perfect coat of matte for the paint situation. Repainting a new color would be a little too crazy for my life right now.
Old Nov 3, 2010 | 10:38 AM
  #1492
naughty240's Avatar
We can have a paint off in the spring haha. When I painted my car brown, my friend who is no longer on the forum did his coupe a crazy flip flop blue. It was pretty motivating getting text updates from each other. Knowing I was not the only one working late helped a lot. It was pretty cool seeing each others finished product too.
Old Nov 3, 2010 | 01:30 PM
  #1493
Heist.'s Avatar
Sounds interesting. I could use some encouragment to keep working on the mess . I'm planning on gutting my interior and redoing all my paint and suede since its chipping and the summer did some damage on the suede. What did you you use for yours?
Old Nov 3, 2010 | 02:02 PM
  #1494
naughty240's Avatar
I used cheap stuff I found online. I will redo it someday with real headliner material with the backing pad. Your better off going to a shop and have them order the material for you.
Old Nov 3, 2010 | 02:16 PM
  #1495
Heist.'s Avatar
Yeah? damn I used the cheap stuff too and totally regret it. It's all faded and coming apart.
Old Nov 3, 2010 | 02:18 PM
  #1496
naughty240's Avatar
Mine is only like 6 months so no fading yet. I learned a lot doing it so its a lesson in itself.
Old Nov 3, 2010 | 02:25 PM
  #1497
Heist.'s Avatar
^lucky I did my dash so it has direct sunlight and I spent my whole summer at the beach. Agreed this was a good lesson should make it easy to perform it all over again . I kinda want a theme, but I need to pick a color combo. Maybe black and Red? dye sections of the seat maybe? do a deep red for the accents mhmmmmm?
Old Nov 9, 2010 | 02:05 PM
  #1498
Heist.'s Avatar
Current wheel setup:
FRONT.
-215/35/19 on 19x8 30mm offset with 25mm spacer (diameter 24.9")
REAR.
-235/35/19 on 19x8.5 33mm offset with 20mm spacer(diameter 25.5")
NEW wheel setup:
FRONT.
-225/35/ 19 on 9.5 +12 (diameter 25.2")
REAR.
-245/35/19 on 10.5 +22 (diameter 25.8")
Difference:
Front.
+1.5" width and +7offset
Rear.
+2" width and +9 offset
Can someone double check my calculations? I think this might be too much stretch for my taste. Might have to go a little less aggressive.
Old Nov 9, 2010 | 02:15 PM
  #1499
CandlestickPark's Avatar
ill Sedan
Your fronts will be 12 mm more aggressive and the rears will be 13mm more aggressive. If you don't want to run as much stretch you could do 235/35 and 265/30 like Cliff (dznuts) did. You'll have to pull your fenders a bit though to fit those tire sizes. I think the 225/245 will be fine, just don't pick a tire size that runs small. Pick one that runs true or large if you don't want a ton of stretch.
Old Nov 9, 2010 | 02:26 PM
  #1500
Heist.'s Avatar
Marcus I'm going to use Generals, but I have fiberglass front fenders now. I'm pretty sure I can't pull that hahaha.
I'm just in fear of making it too obnoxious I like flush not crazy poke. I have been trying to get a better idea with looking at other wheels with the same size, but have yet to get a perfect match.
Thanks again for all the help MArcus life saveR!
dznuts setup is really nice. I'm going to look over that for a little.
