OFFICIAL: Aggressive Wheel fitment FLUSH/STRETCH sedan
Old Mar 25, 2013 | 05:50 PM
  #6931
gtrefever's Avatar
first set up years back when no sedan was really aggressive 19x9+5 19x10-1. New set up is 19x10.5-12 19x11.5-12
Old Mar 27, 2013 | 08:24 PM
  #6932
Roh's Avatar
Roh
going to be going with xxr 521s 18x10 +25 all around with 225/40s. What do you guys think? I will probably get 5 or 10mm spacers after i get the wheels on if i want the setup more aggressive.
What do you guys think?!
Old Mar 27, 2013 | 10:05 PM
  #6933
JosansG35's Avatar
You won't need that much stretch with those specs. I say test fit em first cus you will most likely want more tire in the rear. You can get away with a 245 in the rear.
Also depends how low you're gonna be (hopefully slammed)
Old Mar 27, 2013 | 11:26 PM
  #6934
Roh's Avatar
Roh
I got my inspiration from this car here, Gdup35Sedan's sedan: he's running 18x10 +15 with 225/40 up front and 225/45 in the rear. love how it looks.
I guess i'll see when i get them on. I just gotta figure out tires. I'm thinking 245/35 all around, with the +25, and then go from there?
And yes i will be low, picking up ksport coilovers in a week
Old Mar 29, 2013 | 05:09 AM
  #6935
JosansG35's Avatar
hopefully lower than that pic above. that car isn't even tucking tire.
Old Mar 29, 2013 | 12:17 PM
  #6936
gtrefever's Avatar
That's grants old set up on 18s and he was super low, def hard to tuck tire on 18s. I've only seen blain do it
Old Mar 29, 2013 | 02:08 PM
  #6937
JosansG35's Avatar
Well if you gonna do it, DO IT RIGHT!
Old Mar 29, 2013 | 02:27 PM
  #6938
Roh's Avatar
Roh
exactly, i've been reading these forums for a while now, tryna learn as much as i can, i wanna do it right the first time
Old Apr 4, 2013 | 01:09 PM
  #6939
ekrebs's Avatar
Originally Posted by P10 WRC
profile shot. i really need to get a good camera
Any fender work needed for this set up?
Old Apr 4, 2013 | 01:21 PM
  #6940
P10 WRC's Avatar
yes. I am lower than this now, but with the offset i have, i still needed fender work. Rears are rolled flat and pulled about 2-3mms. fronts are pinched flat completely and flared a bit from natural rubbing.
Old Apr 4, 2013 | 02:20 PM
  #6941
ekrebs's Avatar
what about fender work on your old set up with the ssr sp1's? what were the offsets ?
Old Apr 4, 2013 | 06:30 PM
  #6942
P10 WRC's Avatar
yeah same with the sp1's because i used spacers. What offsets are you looking to get?
Old Apr 4, 2013 | 08:36 PM
  #6943
ekrebs's Avatar
I want to go semi aggressive due to my G being my DD. ill be rolling my fenders flat and running BC coils but im trying to find offsets that will work with Sp1's or Works VS's. Can you recommend an offset i can run without really having to pull fender (much) and that will be DD friendly. What were your specs with your SP1's without spacers? maybe that would work..
Thanks.
Old Apr 5, 2013 | 01:00 PM
  #6944
ekrebs's Avatar
Cliff (dznuts) freshly polished Meisters
What are these wheel specs? fender work?
Old Apr 6, 2013 | 06:44 PM
  #6945
g35loving's Avatar
Just got done with this
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
