Quote:
Well every tire fits differently. And I have 275-30's. so less side wall=more strech.Originally Posted by FlyingLumpia
I also must comment for 10.5 and 275 on there, those tires must run small. I figured they would be more squared on the rim.
CandlestickPark
ill Sedan
close
- Join DateJun 2007
- LocationLong Beach, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(87)
Liked:2,688 Times in 1,449 Posts
LOVE the fitment man, looks sick!
I like the finish on this set of wheels better, goes with you emblemless grill. Paint your roof and headlights black and you'll be all set.
Yes those tires run small than most 275s even for a 30 series, which isn't a bad thing for you cause they fit.
I'm trying to figure out how you fit a 10.5 +23 on there with a 275 tire. I've got a 9.5 +20 with a 255 and my fender is sitting right on top of the tire (no way I could go wider, without adding more camber of course). How much negative camber are you running in the rear? Are your fenders just rolled or do you have a slight pull? Do you rub at all?
NjMatteSedan
close
- Join DateApr 2009
- LocationElmwood Park. NJ
iTrader Feedback Score(3)
Liked:98 Times in 82 Posts
those Volks look sickk. +1 on the roof and headlights DOETT
That is some sick fitment right there, not sure how you got a 275 to fit underneath there with that offset, but nevertheless your car looks good. Are your tire sizes 245/30 and 275/30?
as for camber...i have not added a camber kit to make more camber..the camber i have is what was generated from lowering it. it is 3.5. the quarters are rolled and pulled.not a crazy pull tho there was no bondo involved or repainting. Originally Posted by CandlestickPark
LOVE the fitment man, looks sick! I like the finish on this set of wheels better, goes with you emblemless grill. Paint your roof and headlights black and you'll be all set.
as for the tire thing. a 275 is a 275 if it runs smaller it is still bigger than a 255,265 ect. not tring to be a ***.
Quote:
245-35 & 275-30Originally Posted by heyitzalex
that is some sick fitment right there, not sure how you got a 275 to fit underneath there with that offset, but nevertheless your car looks good. Are your tire sizes 245/30 and 275/30?
CandlestickPark
ill Sedan
close
- Join DateJun 2007
Got it, thanks for the info. Who did the pull for you, how much additional clearance did the pull provide?Originally Posted by dz n.u.t.z.
as for camber...i have not added a camber kit to make more camber..the camber i have is what was generated from lowering it. it is 3.5. the quarters are rolled and pulled.not a crazy pull tho there was no bondo involved or repainting. as for the tire thing. a 275 is a 275 if it runs smaller it is still bigger than a 255,265 ect. not tring to be a ***.
Wasn't trying to say that your 275 wasn't a true 275. My point was that based on how that particular brand of 275s fit on a 10.5 rim you can tell they run smaller than other brands. If you had another brand of 275s you may have encountered rubbing issues and needed more fender work/neg camber to make them fit.
Nice work man!
Quote:
we did it at work.i didnt pull for these.i pulled for the five axis wheels i had. they were 10.5 et33.they poked when i had springs. and when i got coils and lowered it more they tucked.so when i got the gold sf's they were 10 et 25 i rolled the quarter alittle more.seeing i ran these same tires but on a 10 they weren't really stretched and the quarter sat on the tire.lol so to be honest i am not real sure how far i have came out farther than stock quarters because im always messing with it.lolOriginally Posted by CandlestickPark
Quote:
naw. been there done that on multiple cars. dont really want that look this time.Originally Posted by Beebo
Sick! as others have said black roof and headlights
Quote:
no rub...Originally Posted by AARONHL
WOW I like that moving picture. Does it rub?
