post pics of slammed sedans!
Old May 8, 2010 | 09:56 PM
  #196
O HELLA OEM's Avatar
whats the specs on dznuts replica te's?
Old May 8, 2010 | 09:57 PM
  #197
CG4DR's Avatar
they are either jlbs or varrstoen probably..
looks like varrstoen so maybe 19x9.5F and 19x10.5R
Old May 8, 2010 | 09:58 PM
  #198
probably +12's but im wondering what size tires and how much camber hes running also.
i want my stance to be like that but on my g35 coupe!
Old May 8, 2010 | 10:01 PM
  #199
gtrefever's Avatar
if you want a stance like that id go 9.5/10.5 0 all around for a semi aggressive set up.
Old May 8, 2010 | 10:06 PM
  #200
my volk te37's are 19x9.5 +22 front and 19x10.5 +22 rear.
the tires are 255/35/19 front and 285/35/19 rear.
so if i get 20mm spacers ill be at +2 all around. if i get 25mm spacers
ill be at -3 all around. will i need my front and rear fenders rolled flat to
do that? how much camber will i need? sry for the noob questions
Old May 8, 2010 | 10:12 PM
  #201
CG4DR's Avatar
flat or pulled, and probably a couple degrees neg camber
Old May 8, 2010 | 10:29 PM
  #202
gtrefever's Avatar
youd probably get away with 235/35 245/35 with atleast or clsoe -3 upfront and same for the rear. But im not sure dre or shane, i know more about fitment on a sedan then coupes.
Old May 8, 2010 | 10:38 PM
  #203
Matzo Ball's Avatar
I am waiting for dznuts to paint his new set up. Chameleon again???
Old May 8, 2010 | 10:40 PM
  #204
Matzo Ball's Avatar
Originally Posted by Brew_haha
Ahhh, a '05/06 DG dropped and running OEM 19s. Like the younger brother of my car Looks good!
Old May 8, 2010 | 10:41 PM
  #205
CG4DR's Avatar
^ what lip is that?
Old May 9, 2010 | 05:57 PM
  #206
kennymo's Avatar
how do i go about getting a wfc and scrape sticker?
Old May 9, 2010 | 06:00 PM
  #207
CandlestickPark's Avatar
ill Sedan
For WFC sticker you should join the WFC site if you haven't already. You'll then need to have the minimum number of posts and you can submit your car to be WFC approved. Once you are approved there is a guy on WFC that makes/sells the stickers, you can buy some from him.
The scrape sticker you can order from here: http://www.itsproper.com/shop/scrape-vinyl/
Old May 9, 2010 | 06:01 PM
  #208
kennymo's Avatar
awesome thank you for the help
Old May 9, 2010 | 06:06 PM
  #209
ill Sedan
You got it man. I just checked, you gotta have 50 posts to submit your car for approval.
Old May 9, 2010 | 06:12 PM
  #210
kennymo's Avatar
ok thanks. i know mine is not going to get approval yet anyways. i need to get some spacers first.
