Teaser Pics:05 OB Sedan updated: Universal Air Suspension and J lines Wheels
Old Feb 7, 2011 | 09:29 PM
  #31
1lowG35's Avatar
@jacknus My two door brother from another mot.......err factory!
@labguy I actually used my tokico d specs, per my mechanic I could go ahem...."MOAR LOW" if I used the stock shocks.
Old Feb 7, 2011 | 09:54 PM
  #32
labguy94's Avatar
Gotcha - thanks for the info. Was thinking of possibly going with Tokico D Specs or the HP Blues.
Old Feb 8, 2011 | 09:44 AM
  #33
Matzo Ball's Avatar
Originally Posted by 1lowG35
Thank you everyone for your responses. Actually today, my mechanic called me and said the bead popped on the rear tires. I've been hearing that 225/35 or 225/30 is kind of risky on a 10. Is this true? If this is case should I go up to a 235/30 or 235/35?
I would say 235/30 for a good stretch as that 35 profile sidewall may be a touch too large.
Originally Posted by Cali*Coast
I think a wider tire would look better. It looks too stretched. The concave of the tire's edge is a little strange looking. I really cannot comment on the proper size for that rim though.
hush you.
Old Feb 8, 2011 | 10:25 AM
  #34
4DGS's Avatar
I ran 225/35 on a 10 daily without issues (until the end....) as do a lot of people.
What brand of tire are you running? (this is probably the culprit)
Old Feb 8, 2011 | 12:31 PM
  #35
The X Factor's Avatar
Good work, glad to see you're putting the wheels to good use.
Old Feb 9, 2011 | 01:15 AM
  #36
NFSP G35's Avatar
? = 2B || !2B
Hey man. Your "lazy login mode" confused me!
Look forward to seeing the car again, I won't even recognize it!
Old Feb 9, 2011 | 01:21 AM
  #37
da mayor's Avatar
nice progress
Old Feb 10, 2011 | 06:20 PM
  #38
1lowG35's Avatar
As a note, if you use tokico d specs you wil have to machine the plates that come with it for ahem "moaaaaaaaar" low in the front.
Old Feb 11, 2011 | 03:00 AM
  #39
The Stimulation's Avatar
@MTG Thanks
I was getting quotes of 1300-1800 for u.a.s install
Wow, that's so much for the install. UAS charges 1k if you take it to them.
Bead popped? Hmmm...what was the PSI at? Was it while driving? If so, my guess is either low pressure, the tire itself not being good (if it's used), or how the fender is hitting the tire. I'd say add a little more negative camber.
BTW, I ran a 225/35 on a 10.5. It didn't look all that good, had a little gap but no issues until I let the air get too low and then the bead unseated while driving. Currently I have a 235/30 on a 10.5 and I've never had any issues with it. If you have the room go as wide and tall as possible.
Old Feb 11, 2011 | 03:13 AM
  #40
1lowG35's Avatar
I think i'll order 235/30 on my next go round on my 20x10. He did mention that the tire appeared low.
Old Feb 11, 2011 | 11:08 AM
  #41
Ah ok...when running stretched you definitely want to keep your pressure up. Check it constantly. Which reminds me I should check mine today. I let mine get to the low 20's, not good when running stretched. I don't even like mine getting to the low 30's.
For reference, here's the 235/30 on the 10.5:
Old Feb 11, 2011 | 12:24 PM
  #42
Songle6MT's Avatar
^your wheels are bad***
Old Feb 11, 2011 | 12:46 PM
  #43
Lol, thanks. I'm actually selling them.
Old Feb 11, 2011 | 10:05 PM
  #44
1lowG35's Avatar
MOOOOOOOOOOOORE PICS!
Old Feb 11, 2011 | 10:40 PM
  #45
O HELLA JDM's Avatar
^^^^ nice!!!!
