control arm woes
Old Nov 13, 2015 | 10:50 PM
djsniperwolf's Avatar
control arm woes
Hello all. I thought I was registered here but i guess not.
I own a 2003 G35 Sedan. It was in an accident last year where the driver side was impacted destroying the spindle, control arm, etc. My first mistake was having my insurance choose the shop.
After the work was done, i noticed the alignment was way off base. I mentioned this to the shop which blamed it on worn passenger suspension parts (not covered under claim I guess)
So my wife continued to drive it vicariously, fast forward to today. The issue became so bad that the car would feather on the freeway even at speeds below 60. Scary as hell.
I ripped apart the suspension myself and couldn't beleieve the amount of worn control arm and sway bar bushings. On both sides! The compression bushins were basically gone with metal on metal contact.
Pressed all the bushings, replaced with energy, installed Z shocks, etc. I went to put the castle bolt on the driver side ball joint when i noticed the cotterpin hole is covered by the control arm. I checked the pasnger side, it is beveled in much deeper allowing the castle nut to seat and the cotter pin to slide in.
Soo.. before I proceed to replace the control arm and blast the shop for shoddy work (loose steering knuckle bolt, etc.) I'd like to know what car this control arm is from..
part number 2WL 44-1
My passenger side is 2wr 10-0 if that helps.
I will see if they used the correct spindle and compression rod as well. Everything seems a bit wonky on that side.
Thanks.
junon
Sep 5, 2015 10:40 PM
jbmw002
Sep 3, 2015 08:42 PM
SFLG35
Sep 1, 2015 10:44 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
