Advan Racing RZ Dark Gun Metallic 19x9 +25 19x10 +35
the only thing i recommend doing is changing your turn signal bulbs to the stealth auto bulbs.....you already did the hard part by taking out the reflector inside the headlight...now finish it up by replacing that orange bulb with a stealth bulb...then you'd be complete
the setup looks
i like
what bulbs are you referring to?? pic or link. i changed every bulb except the backup and turn signal in my car.
i like
GREAT set up. I'm very partial to Advans.
As for whether yours is the most aggressive, you're definitely pushing it, but I think there are a couple of people w/ just as aggressive, if not slightly more aggressive set ups:
Kalvinmaui is running F: 20x8.5 +38 and R: 20x10 +38 with 10 mm spacers all around. So, your front is more aggressive, but his rears are basically 20x10 +28.
ommmjido is running F: 19x9.5 +35 and R: 19x10.5 +40 which would be about a millimeter pushed out more than 19x10 +35:
https://g35driver.com/forums/showpos...&postcount=591
ommjido also previously ran 19x9.5 +41 and 19x10 +37:
https://g35driver.com/forums/showpos...11&postcount=1
kalvinmaui also ran some 19x9 +26 and 19x10 +26 Work Euroline S2Hs, but I'm not sure if he just test fitted them or drove with them for a while:
https://g35driver.com/forums/showpos...15&postcount=1
AlterZgo
https://g35driver.com/forums/showpost...&postcount=591
https://g35driver.com/forums/showpost...11&postcount=1
https://g35driver.com/forums/showpost...15&postcount=1
Wow, car looks sick bro.
I'm definitely PMing Gdup35sedan when I'm ready to order up some wheels for some advice on the offsets.
You should get the black roof overlay to complete the look.
