IForged Neo's Prelim Fit.
Old Oct 24, 2008 | 05:24 AM
B L U E S L A T E's Avatar
Honda Accord
Holy shiet... what's the spec on those wheels?
Old Oct 24, 2008 | 05:32 AM
Borna's Avatar
Those look sick, you should grab yourself a set of coils and drop the ride.
They'll tuck away no problem with a bit of neg. camber.
Old Oct 24, 2008 | 05:39 AM
Honda Accord
It will def. need some tire stretching and neg. cambers tho'...
Sick looking wheels BTW!
Old Oct 24, 2008 | 05:42 AM
Borna's Avatar
True, btw Alan how much neg camber are you running with your setup?
I'm guessing you just stretched 245/35 and 275/30 tires on it right?
Old Oct 24, 2008 | 05:48 AM
Honda Accord
Yup.
By the looks of his setup... depends on how low he wants to go (assuming coilovers), he'd have to put somewhere around -2.0... and I'm not sure if 275 will work with that offset... it just seems a bit too aggressive. Maybe 255/30 stretch would work?
It would def. help if OP can post up the specs of the wheels...
Old Oct 24, 2008 | 05:51 AM
Borna's Avatar
I also highly doubt he'd be able to put anything above 255/30 without rubbing issues.
We'll just have to wait for the specs then.
Old Oct 24, 2008 | 07:49 AM
AAMC's Avatar
They're 20 X 8.5 in front with 20 X 10 in the rear. IForged doesn't release offsets. I'm gonna throw the rears back on today and cycle the suspension. I have a feeling the rears are off too.
Old Oct 24, 2008 | 11:16 AM
Wannabe6MT's Avatar
-MN G Crew-
Holy crap.
Wheels look good though
Old Oct 24, 2008 | 01:05 PM
ttrank's Avatar
Grocery getter
My rears stick out about that far when the car is in the air. Those might fit.
Old Oct 24, 2008 | 01:32 PM
redlude97's Avatar
+1, people just need to understand suspension geometry
Old Oct 24, 2008 | 01:47 PM
Hi-TechG35's Avatar
Nice wheels!
Old Oct 24, 2008 | 07:42 PM
Honda Accord
Hm... if you have 10 inch wheels in the back that sticks out like that, the offsets must be pretty low. I'm running 10.5 with +37 and sticks out about as much as yours, so maybe if you're willing to go for a little stretched looks, you'll be able to fit those wheels pretty nicely.
BTW, did I tell you how much I like those wheels?
Old Oct 24, 2008 | 08:08 PM
AAMC's Avatar
Did you post up your full side shots yet, or did I miss them. I'm diggin' your new wheels too.
Old Oct 24, 2008 | 08:12 PM
Honda Accord
I just put them up on the other thread. Check them out.
Old Oct 24, 2008 | 11:08 PM
  #30
EWG35's Avatar
Dude, you'll be fine. I have a camber kit on mine so the top of my wheels will possibly stick out farther than yours. My wheels also stuck out an inch while on the jack. I'll bet you're happy once mounted.
PS: I'm running 275/30 20 in back. No problems.
