G-Sedan with 370Z Rims...
Old Feb 27, 2009 | 05:54 PM
  #31
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by Jeff92se
I think it's photoshopped?
posted in November.... definitely a chop.
& sizes are free hand.
look more like 20s in some pics.
I've seen these on the Z & they look great, I'm not sure they suit a sedan.
Old Feb 27, 2009 | 07:17 PM
  #32
soakgame's Avatar
it works.. that's a good look!
Old Feb 28, 2009 | 11:24 AM
  #33
E-Ticket Ride's Avatar
A set sold on eBay for 1g a few days ago
Old Feb 28, 2009 | 02:54 PM
  #34
jsmonet's Avatar
it doesn't work.
Old Feb 28, 2009 | 08:18 PM
  #35
baileyt35's Avatar
I was going to say yuck until I saw the last photo with the drop. Initially without the drop the rims looks so beefy and bulky. But with that drop, very nice!!!
Old Feb 28, 2009 | 09:42 PM
  #36
I'd run these if they fit. I like their look, they're light (forged), and they're wide too.
Plus, they look way better than a lot of AM rims I see guys running.
Old Mar 1, 2009 | 05:51 AM
  #37
psedog's Avatar
Back in SD**
DOOOO IT!
Old Mar 1, 2009 | 07:04 PM
  #38
95 maxima se's Avatar
doesnt look that bad
Old Mar 1, 2009 | 10:45 PM
  #39
AlterZgo's Avatar
370Z rim specs
OK, I'm sure others are probably curious about this also. So, I poked around my350Z and found the following specs for the 370Z rims:
This is the offset for the z34, as listed in the 2009 370z owner's manual. I am sure these are subject to change. It lists both wheel options.
Standard:
front - 18x8, +43
rear - 18x9, +15
Sport package:
front - 19x9, +47
rear - 19x10, +30
To install these on a G35/37 sedan, looks like some +15 to +20 spacers would be good for the front, but the rears may not work unless you run 255-40-19s and/or run more negative camber, or possibly mill down the hub area a bit (would 5mm be safe?) to get it to a +35 offset.
Old Mar 2, 2009 | 01:54 AM
  #40
Thanks for doing all the legwork. It seems like it's too much of a pain in the *** (at least for me) for us to use. What a shame.
Old Mar 2, 2009 | 01:59 AM
  #41
The Stimulation's Avatar
1st pic looks good, 2nd pic looks eh, and 3rd pic makes it look like a crossover suv
Old Mar 2, 2009 | 02:10 AM
  #42
Beebo's Avatar
i think they would look good but the car needs a drop
Old Mar 2, 2009 | 02:22 AM
  #43
MTG35guy's Avatar
I think it works. I like it.
Old Mar 2, 2009 | 07:30 AM
  #44
InTgr8r's Avatar
I would definitely NOT recommend doing that.
You'd be taking too much away from the seat for the wheel nut.
That'd be too much of a safety issue for me.
Old Mar 2, 2009 | 09:05 AM
  #45
InTgr8r's Avatar
Sport package:
front - 19x9, +47
rear - 19x10, +30
OK....
out of curiosity I ran these through an offset calc.
Comparing, OE sports @ 7.5 et45 fr & 8.5 et50 rr.
& Using the above 370z specs
Fronts - will be 21mm closer to the strut & extend 17mm further to the outside.
Rears - will be 1mm further from the strut/inside & extend 39mm further to the outside.
