New Stuff: Hikkatadori "KS" Style Front Lip and Advan RS-D Wheels
Old May 26, 2010 | 03:07 PM
jran76's Avatar
Originally Posted by g37Mobbin
wierd cause when i tried to do 275 i rub'ed that is why i had to go 245 all around hmmmm
What are the specs on your rear wheels? Is this on the SF-Winnings?
Old May 26, 2010 | 03:59 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Thumbs up
Great work...
RS-Ds are one of my favorites, can't wait to see them mounted.
Old May 26, 2010 | 04:03 PM
Defratos's Avatar
You're Despicable
Originally Posted by LightsOut
dont you think 275 might be too wide? maybe a 255 tire would be a better fit.
Hummmmm My Yokahama Advan RZ 19x9 +25 are on 275s on the rear, they used to be on 255 but I used to bottom out with that every time I'd go into my drive way, so I wanted to change to 265 but only found 275s, I don't like the way they look so I'm going to be changing them soon but I don't rub at all with 275s and I'd say camber is about -1.5 or less.
but then again mine are 9" on all 4 wheels
Old May 26, 2010 | 04:29 PM
jran76's Avatar
Your 9" +25 is pretty close to my 10" +35 on the rear; mine will be about 2-3mm further out, but I will also have more stretch on the tires (so we should be real close). I based my assumption that they will fit with around -2 degrees on your car and heyitsalex (?). I think he ran the same Advan RS, but with a 10" +35 in the rear with 275's and I think he was in the -2 degree or less range.
Old May 26, 2010 | 04:52 PM
LightsOut's Avatar
SIETESG
after thinking about it, you'll be able to get them to fit.
a est of -2.5 range of camber should do it
Old May 29, 2010 | 02:49 PM
Defratos's Avatar
You're Despicable
Dude where r the pics!!!1
Old May 30, 2010 | 12:09 PM
jran76's Avatar
I am waiting on the tires to come in. One of them was on back order, and it will probably be another week, or so.
Old May 30, 2010 | 12:54 PM
Defratos's Avatar
You're Despicable
k
Old May 31, 2010 | 02:03 AM
yosbunjong's Avatar
Hi..Josh Great work!!!!!!!!!!!! Can't wait for pics! So put them on NOW!!!
Old May 31, 2010 | 02:09 AM
Bigtime's Avatar
the front looks sick! In for picks.
Old May 31, 2010 | 11:33 AM
Borna's Avatar
Front lip looks great jran, can't wait to see the wheels on. You'll be fine with those specs and tires with -2.20 camber out back, maybe less if the tires run a little small (more stretch).
Ernie, you need to get new wheels with more aggressive offsets. Especially the fronts. lol (Get winnings again but more aggressive )
Did you get the headliner done yet?
Old May 31, 2010 | 04:50 PM
g37Mobbin's Avatar
sorry to hi-jack the thread...right now, i am waiting for the s/c...possibly color change...i might change wheels if i do color change...the whole reason of the wheels was due to the 8 pot rotor being so huge so had to get an offset that barely clear it. I am not avoiding the Q about what the offsets are just was never told the offsets due that it was someone else hands to get it going.
Old May 31, 2010 | 06:28 PM
2GoRNot2G's Avatar
Originally Posted by jran76
I think I can get the 275 on the rear with a little over -2 degrees, but we will see. For now, I am going to have to run enough to make them fit, although I may go down to a 255 next time if I am way over -2 degrees. I would prefer to keep the camber under -2 degrees if at all possible.
I am flush with a 9.5+37 and a 275 tire now at about -1.6 degrees. So, these new wheels will stick out about 8mm further, but I will get a little more stretch with the 10" wheel this time (I figure about 2-3mm worth). So really I need to make up for around an additional 5mm by dialing in more negative camber....
You should have no problem running your set-up. I'm currently running 20" x 10.5" with a +37 mm offset and 285/30R20's and I don't have any rubbing at all with -2.5° camber. I used to have 275's on the rear and was able to run -2.3° camber with the stretched tires. I'm betting you can probably get away with -1.9° to -2.1° of camber in the rear depending on how much your rear tires stretch.
Old Jun 14, 2010 | 03:19 PM
jran76's Avatar
Wheels are on! The front is perfect with the 245/35/20 tires and about -1.8 degrees of camber. The rears with the 275/30/20 need a tad more negative camber. I am at about -1.6 degrees now, and I should not have to go over -2 (my main goal).
I will take some pics tonight while I am at a our weekly meet, and also after I get my alignment done tomorrow at Cobb....
Old Jun 14, 2010 | 03:22 PM
  #30
2GoRNot2G's Avatar
Awesome! Can't wait to see the pics!
