Slammed V36 Sedan Thread
Old Mar 15, 2011 | 09:57 PM
  #136
07IMLG's Avatar
haha yea beezy 4 years in the making lol still doing stupid things, im around 24.5in's front and back. Thanks candlestick
Old Mar 15, 2011 | 10:02 PM
  #137
CandlestickPark's Avatar
ill Sedan
What are your wheel/tire specs? Suspension?
Old Mar 15, 2011 | 10:07 PM
  #138
07IMLG's Avatar
20x9F 225/30/20 Hankook V12 3/4inch spacer, 20x10.5 255/30/20 Hankook V12 1/2in spacer. Tanabe pro coilovers, removed the front lower locking ring, to get the the front down more. SPC camber kit all around.
Old Mar 15, 2011 | 10:16 PM
  #139
ill Sedan
Very nice. I guess coils don't get you very low for the 2nd gen given the work you had to do to get down to 24.5". What are you offsets before the spacer?
Old Mar 15, 2011 | 10:20 PM
  #140
07IMLG's Avatar
YEa tanabes dont allow much for adjustment, i should have went with BC, before the fronts were 38mm and rear is 45mm
Old Mar 15, 2011 | 11:01 PM
  #141
beezy619's Avatar
How much camber are you running? My rears are +30 with ~-4 camber and im barely at 25 1/4. I don't even think I can go any lower without tucking rim. Can you still drive around with passengers without rubbing?
Old Mar 15, 2011 | 11:13 PM
  #142
timmy_2's Avatar
Heres mine
This is what I am talking bout!! Speedbumps are definitely not your friend.
Old Mar 15, 2011 | 11:14 PM
  #143
07IMLG's Avatar
I will be getting a alignment sometime next week to see where my camber is at, but for the looks at it im prob around 3-4 in the rear, front prob around 2. Tire size does world of difference, with your bc coilovers will be able to go lower then 24.5. Havent had anyone in the backseat, right now im still not rubbing, only my upper control arms hit the inside of the fender. Not sure what im going to do.
Old Mar 15, 2011 | 11:22 PM
  #144
beezy619's Avatar
Any more pics of the front and rear tire fitment? I'm planning on going with a 225/35 and 255/35 for my next set of tires. Is there a big difference between a 30 series and 35 series?
Old Mar 16, 2011 | 09:13 AM
  #145
Capthook's Avatar
That is a hard question to answer..... It really depends on the tire. You could always do a 245/35. It pulls the tire a little more but still have a bit of side wall. I am running a 245/35 on a 10.5 w/ no rubbing.
Heres mine
Love the headlight color. Did you do them yourself? Great stance! I am not on coils but I was thinking about cutting the rubber mount in the rear to tuck the tires.
Old Mar 16, 2011 | 09:33 AM
  #146
07IMLG's Avatar
No I had the body shop do it. Beezy between 30 and 35 series is around .9in diameter difference on the hankook v12 tires. Heres some quick side shots
Old Mar 16, 2011 | 02:22 PM
  #147
JDMPenn's Avatar
Damn I can't imagine that. Is that bad? lol. What would happen in the long run?
Old Mar 16, 2011 | 09:09 PM
  #148
beezy619's Avatar
Thanks for the pics bro. Even with the smaller tires, the stretch still doesn't look that drastic. I expected the stretch to be a whole lot more.
Old Mar 17, 2011 | 10:12 AM
  #149
07IMLG's Avatar
No problem, yea i didnt want to stretch the tires to much, because of the low profile tire.
Old Mar 17, 2011 | 05:09 PM
  #150
beezy619's Avatar
How's the ride compared to your old tires?
