camber questions
camber questions
hello forum, i recently bought a 04 g35 coupe and you guessed it i need tires on the rear. currently on stock 18s and i wanna currect my camber. i am siitin at -1.6 on the left and -1.4 on right. lookn at the kinetix kit and dont plan to drop the car. just want to get max life out of my tires. should i get get kit off ebay and go more positive of course. what the ideal degress for my ride ive been told -0.5 for even wear plz help the newbie
-1.6, -1.4 i would love to have that...mine is at around -2.0 and having trouble getting it any lower without the toe being to far off OEM specs -1.6 is considered within OEM range tho
My rear tires are at -1.02 degrees of camber on each side, I've installed an SPC toe and camber kit because otherwise my rear would be discombobulated since I lowered my car.
The rear camber should be between -0.17° and -1.17° on each side. Don't forget about the toe, which should be between 0° and 0.22°.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
