Clunking noise on even surface
Old Apr 3, 2016 | 08:38 AM
Jason Flynn's Avatar
Every time I drive on uneven surface roads or hit certain bumps that I get a clunking noise that comes from the left front. I have no idea where it's coming from because I had my car on the lift and non of the bushings look worn or loose. I replace the front struts and the noise came back not even a day later. I had a shop try to figure out the noise and they were stumped. the noise is bothering me to point that I want to drive the car off a clif. Lol
Old May 7, 2016 | 06:20 PM
_KyL_'s Avatar
its an Infiniti. You can replace your front lower rear control arm bushings like I did. But youll be back weeks later like I was with the same problems.
Old May 7, 2016 | 08:47 PM
DeafBringer's Avatar
Or just do it right unlike Kyl and replace the OEM compression arm bushings with polythene bushings with silicone grease and you won't have any more problems.
01yellowr
Steering & Suspension
Aug 20, 2016 03:45 PM
the3kgt2
Engine - Power Adders
Mar 8, 2016 11:47 AM
KessG35
Mar 5, 2016 08:41 PM
bighamsterneck
Southern California
Mar 4, 2016 04:59 PM
