06 G35 Coupe Fog Light Not Working
Old Jan 4, 2017 | 09:19 PM
Idris Yusuf's Avatar
Unhappy 06 G35 Coupe Fog Light Not Working
I've done quite a bit of searching through various threads and stickies but couldn't find a any direct help in regards to my situation.....
I recently swapped out (attempted to swap out) my stock fog light bulbs for led bulbs. After plugging in the new led into the driver side fog, there was no light... I replaced the original bulb into the fog and again, no light. I checked the fuse box behind the battery and the 15A fuse is not burned and checks out okay with a circuit tester, so I'm sort of confused as to what my problem here is.
Does anyone here have any tips on how I should continue troubleshooting? I don't see any char marks/melting on the fog wire itself so I don't think this would be a harness problem, however I don't know too much about wiring/lighting.
(Also, I tried checking the fog wire itself for voltage, but the circuit tester only seems to work when it's directly connected to the battery ground and is not long enough at that position to reach the driver fog area)
**** I posted this in the wrong area, sorry, noob here :/
Last edited by Idris Yusuf; Jan 4, 2017 at 09:51 PM. Reason: Posted in wrong forum
Old Jan 9, 2017 | 02:08 PM
VxG's Avatar
VxG
Try rotating the LED light clamp thing that goes on the bulb or checking if the harness is plugged in correctly.
I had some issues with my 6k LED's turning on when I installed my aftermarket headlights, one of those two fixed the issue for me.
Old Jan 9, 2017 | 06:52 PM
Urbanengineer's Avatar
He fixed it, wiring issue (other thread).
