Coolant temp gauge faulty
Old Jan 13, 2017 | 11:43 PM
Mr7's Avatar
Mr7
Ok ima some what new to the G35 community but i have never in my life ever came across a problem like this before in any of my vehicles..i have searched this forum for a member having the same issue but close but not the same..ok when i start my car in the mornings or when ever I know the engine is cold my gauge say my engine is at normal driving temp. Already as if the car has been running all night while I been sleep but no heat will come from the vents untill after the engine warms up...even once it's warm (drive for atleast 30mins) gauge don't move just sits in the middle dnt rise dnt lower dnt fluctuate at all...kinda scared to drive it for at least a hr cause if it's gonna over heat, I know my gauge probably want tell me the truth? Any solutions ...im thinking one of the coolant temp sensors but i know these cars have 2?
Old Jan 14, 2017 | 07:02 AM
Blue Dream's Avatar
I drove ttrank's car solo
One of the most valuable assets I have for all of my cars is the factory service manual. Search the forum for member psedog, he has links to all first gen FSM's.
Personally in almost 9 years here I've never heard of this issue. You might also send infinitidude a PM, he's a member here and a certified Infiniti tech. Great guy!!
Old Jan 14, 2017 | 02:27 PM
telcoman's Avatar
Veteran: Army
As BlueDream has mentioned you need to follow the troubleshooting steps in the FSM
Not sure why you would make such a post without mentioning the year, model, and mileage of your vehicle while expecting assistance from an online forum?
http://www.nicoclub.com/service-manu.../Sedan/2004/co
http://www.nicoclub.com/service-manu.../Sedan/2004/ec
I would strongly urge you to spend the one hour diagnostic fee at an Infiniti dealer to give you the root cause of your problem prior to you just guessing,wasting time,money and replacing non OEM sensors without being sure of the cause.
If you haven't replaced coolant, radiator cap, belts, thermostat, and water pump, confirmed cooling fans are functioning and your vehicle is over ten years old it may be time for you to spend some serious money?
Just my $.02
Good luck
Telcoman
Old Jan 15, 2017 | 01:26 AM
coffeysm's Avatar
Could be a faulty ECT or maybe the cluster is going bad. There is a test I think you can do on the console to see if the fuel and temp gauge mvoes.
Old Jan 17, 2017 | 10:30 AM
Mr7's Avatar
Mr7
Well telcoman it's a 05 with 170 on odometer its crazy some days it works then others my gas gauge will go up. But I guess I'll try the FSM you were saying ...i took it to a shop and they only said i need to replace my belt and front control arms nothing's about water belt ,coolant, fans etc.
But preciate the responses
Old Jan 17, 2017 | 11:04 AM
telcoman's Avatar
Veteran: Army
When I had my 06 G35 6speed (purchased new) I had to make a serious financial decision when it needed a couple of thousand dollars of work. I decided to trade it in at 171796 miles for my present 2012 G37S. It came with all new parts, a warranty, navigation, back up camera and other features that I did not have in my 06.
You can pour many $$$$ into your 05 G but after you do it will not be worth any more than it is today.
While in Florida last month I had the opportunity to speak to the owner of this 32 Ford for a few minutes which I've always wanted since high school.
He told me he spent $100k to restore this vehicle with a Chevy V8 and auto trans.
With an antique vehicle one can obtain a special insurance policy to insure the value of the vehicle.
In your case an unfortunate accident that totals your 05 G is only going to give you book value as determined by your insurance company which is not much no matter how much money in repairs that you just spent on it.
Just my $.02
Telcoman
