Electrical issue - dashboard, alternator, a/c, trunk
Old Apr 15, 2017 | 05:41 PM
Nathanniice's Avatar
I was driving and without waring the dasboard lights and gauges cutout on me. The radio kept working and the car ran until the battery died. I'm clueless to the cause as the car started right up when I put a new battery in. It also died after a fe uses. Putting in the new battery did nothing for the dashboaRd lights guagues, and the ac still didn't work along with the trunk. The alternator is my guess but a friend said that I might have blown a fuse to the alternator dye to hooking ip the battery jumper cables wrong when I jumped it.
when u jumped ut the car died while linked to another car. So that tells me that a fuse is bad, but u f urge oouuu]
so I have new battery and no Electrical power to the dashboard cluster , the a/c won't turn on abd trunk won't open. What could it be?
Old Apr 18, 2017 | 06:01 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sorry man I couldn't finish reading your post, it was too painful.
"fuse is bad, but u f urge oouuu]" and we're seriously supposed to have a clue what the hell you're trying to say? Quit posting drunk/high and you might get more responses that are helpful and positive.
Old Apr 18, 2017 | 10:59 AM
telcoman's Avatar
Veteran: Army
Go back to school and learn how to write.
You are not qualified to use jumper cables if you connected them in reverse.
Most likely you caused electrical damage
Next time call AAA
A dealer most likely can fix it and it will be an expensive lesson for you.
Good luck
Telcoman
