brakes upgrade
Not a bolt on, requires custom fab brackets due to different size (smaller) rotors. If you have an '06 or newer coupe then the stock brakes are better anyways, if '03-'05 it's basically a wash, stock is a larger diameter rotor, 300ZX is a better caliper.
If you want a reasonably priced upgrade either look for a used Akebono kit or a G35 stock Brembo kit.
