Slip and VDC light
Old Oct 30, 2019 | 11:00 PM
Ethan Gilbert's Avatar
03 G35 Coupe 5AT
Slip and VDC light
I have a 2003 G 5AT. The slip and vdc light are both on with no check engine light or abs . I have checked brake fluid, brakes but they remain on. I don’t have loss of power or anything and the car rides just like normal. Any ideas? IT ENDED UP BEING THE CLOCK SPRING CAUSING ALL THE ISSUES.
Old Oct 31, 2019 | 01:39 AM
Scorpi0's Avatar
Damn. There are a million things on this car that can cause those lights to come on.
Old Oct 31, 2019 | 12:23 PM
Polishthrust's Avatar
Did anything change on the car recently, like new tires?
Old Oct 31, 2019 | 12:55 PM
coffeysm's Avatar
Do you have RAS?
Old Oct 31, 2019 | 05:25 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Get it scanned with one that does body codes, then you will know what sensor is triggering the light.
Old Nov 2, 2019 | 10:19 PM
03 G35 Coupe 5AT
yes I recently replaced the wheel bearing, but it was even on before that.
Old Nov 2, 2019 | 10:32 PM
03 G35 Coupe 5AT
The only thing I have going for me is there’s no check engine light or abs which normally goes along with those 2. If that helps anyone.
Ethan Gilbert
Nov 1, 2019 12:22 PM
snunez
Oct 27, 2018 03:29 PM
