Used JDM transmission HELP
Old Nov 4, 2019 | 08:33 PM
Zklastorin's Avatar
Infiniti G35 Sedan RWD
My transmission went out on my 2005 g35 sedan RWD and I’m considering getting a JDM tranmission. Any problems or suggestions? Would it fit and would I be able to pass smog with a JDM tranny?
Old Nov 4, 2019 | 11:05 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Literally the exact same transmission. They are all made in Japan, not the USA, Japan.
Old Nov 4, 2019 | 11:06 PM
cleric670's Avatar
BANNED!!!
Your vehicle will probably need to be programmed (TCM) so keep that in mind. Make sure you buy the correct transmission. Pull the numbers off the ID tag.
Old Nov 5, 2019 | 01:03 AM
Zklastorin's Avatar
wheres the Id tag? The vin number tag u mean? And wouldn’t the shop program for me after they install.
Old Nov 5, 2019 | 11:46 AM
cleric670's Avatar
BANNED!!!
No I mean the transmission tag, it's on the side of the transmission. Call the shop to verify they have to tools to do the necessary programming, I have no idea what tools they have.
Old Nov 9, 2019 | 01:41 AM
Zklastorin's Avatar
thanks JDM is installing it so I’m pretty sure they would have the right tools to program it
Old Feb 20, 2020 | 03:51 PM
quickspeed6's Avatar
I am about to do the same thing so what was your results? Did you have to change anything? Did you have to have it reprogramed?
