I'm installing silvers neomax super low true coilovers I just got and I ordered z1 motorsports front uca and rear camber arms and rear traction arms and spc toe bolts I'm going to be dropping at least 2 inches since that's the minimum with the super low kit will the SPC toe bolts be enough or do I need to order the toe arms I have no problem spending the money if that's what I need thanks any help is appreciated I already have the coilovers
cleric670
BANNED!!!
close
- Join DateMay 2017
- LocationWashington State
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideCoupe 6MT Premium RAS
Liked:2,497 Times in 2,182 Posts
TRUE coilovers will have an adjustable lower arm (replaces the spring bucket). It will have the adjustability you need.
If it uses the existing spring bucket then they are NOT TRUE coilovers. 2" drop will not be able to get the toe in spec.
Yes I'm aware what true coilovers are and mine are Indeed true . My question was can I get withing specs with toe bolts with a minimum of 2" drop I already bought the spc toe bolts or should I just get toe arms
