Need help car shut down
Old Jun 28, 2023 | 03:40 AM
Slougee99's Avatar
G35
Originally Posted by Soular
Hey there this is the unit they called an IDPM... its just a modular fuse box. this is on the right side of the car under the battery cover in the same hole as the battery. This unit is inside a black box of its own..
This the location of the box in the 2door coupe.. not sure about the 4 door version of the car. You have to get the right one.. meaning that the coupe's IPDM is not interchangeable with the 4 door.I also think its best to get one that is the same year as your car. So for example I have a 2005 G35 Sport Manual so that was the box I looked for.
I found a replacement on Ebay
https://www.ebay.com/p/5011613042
Ebay search for Coupe IPDM
Just got to ebay and enter your cars year and type and you will see various junkyard offering the part. $180 is what I a seeing.
When I got mine it was like 95$ to 130$ at the time... looks like prices have gone up...(greedy junkyards)
If water is getting in your battery box you have to mitigate that. make sure you IPDM is in that black box and that box has its top.
Also make sure you have the battery hole cover on ans make sure the area on the windscreen has all that plastic is in place.
Finally make sure you have that long foam piece that spans across the engine bay from the right to left side that fits over the raised area at the back of the engine bay... it goes from the battery box all the way to the other side of the bay... it helps form a seal that routes water away from the engine bay.
99$ https://www.asolutionsauto.com/produ...x-284b7aq01b-1
here is the full IPDM with case
Turned out water seeped under my windshield and into my passenger foot area, shop said water fried my main conputer, they ordered and programmed a new one. $1400
Old Jun 30, 2023 | 12:16 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You sure it seeped under the windshield? It's very common for the sunroof drains to clog and drain water into the car, or the engine main harness seal at the firewall to leak if it's not
Old Jul 1, 2023 | 08:26 AM
Slougee99's Avatar
G35
yup that is what happened! So much money spent
Old Sep 3, 2023 | 06:47 AM
BernardWilliam's Avatar
suv
Originally Posted by Muzi Moh
So I was driving pretty agressively today and all of sudden the rpm kinda started vibrating , the engine lost all power and slowly shut down . I had to tow the car away . It's a g37 6mt . When I try to start it it cranks or but it won't start . The battery is good because everything powers on and it cranks . But it just won't start . I popped the hood and found out there's no coolant in the reservoir but to my knowledge the car never over heats. Can anyone help me with this ?
Anything mechanical has a chance of failure if not properly maintained.
Old Sep 3, 2023 | 08:09 AM
Slougee99's Avatar
G35
Hey so the mechanic is telling me the ecu isn't sending a command to the spark plugs to spark . Everything else is fine just won't start it cranks. Any ideas on what it could be ?
Same exact thing happened to me, water found its way on the passenger side and dripped down behind the dash and ruined my pcm. $1300 for new pcm and programmed. Check for water leaks on passenger side foot well. I changed all cam/crank sensors, battery, fuel pump, starter, plugs and all coil packs, new engine grounds, Everything! And it was the pcm. I spent so much in new parts i regret not taking it to a shop from the beginning. These cars are notorious for water leaks when the windshield seal goes bad. Feel free to msg me. Car would crank no start until the batt died and my code scanner would show connection error codes.
edit- the water seal (large rubber grommet)that went bad was passenger side from engine to behind dash. Where the wiring harness runs into car. The windshield rubber seal attatched to the plastic was falling apart allowing water to flow into the passenger foot well. Fingers crossed for you but if u have a connection error its most likely your scanner cannot connect to the PCM
Terry_G35
May 9, 2020 01:39 AM
jivan balwant
Feb 11, 2016 04:51 PM
