Power Steering Cooler
Old Mar 21, 2021 | 05:46 PM
Ted Davenport's Avatar
G35X Sedan
We have a leak in our 2004 G35x (AWD) Power Steering Cooler. Leaking from the fins. It looks like the part has been discontinued, but you can still get what looks like the same part for the 350z. Anyone know if they are compatible. Sure looks like it from the picture...but I know that can be deceiving. Any help would be appreciated.
Thanks, Ted
Old Mar 21, 2021 | 08:35 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The OEM part has likely been discontinued but I bet there's plenty of aftermarket ones available.
You could also try eBay if you wanted to get a used OEM one, eBay is the biggest used auto parts seller in the world.
Old Mar 21, 2021 | 09:31 PM
G35X Sedan
Thanks Cleric. The one I found for the 350Z was an aftermarket. I was unable to find an aftermarket for the G35x that was an exact fit in to the stock brackets. I was hoping not to do anything other than a quick swap and bleed.
Regards,
Ted
Old Mar 22, 2021 | 10:58 AM
cleric670's Avatar
BANNED!!!
In that case I would definitely just get a used OEM one off eBay.
Old Mar 23, 2021 | 12:24 PM
G35X Sedan
Thanks. I may try the 350z aftermarket one prior to going used. I will update this thread when I have figured out whether it will work.
Regards,
Ted
