2007 Infiniti g35 sedan HR Flame kit
Old Jan 8, 2025 | 10:09 PM
gace313's Avatar
2007 Infiniti g35x
I was trying to install the hotlicks flame kit and I was trying to know if there is a certain place to put the ground wire in the trunk because I put it on one of the screws where there are ground cables and when I use the flames the car shows at check and the shifting lights disappear from the dash and also shows the amber key sign
Old Jan 9, 2025 | 10:25 AM
Urbanengineer's Avatar
I would check your grounds for corrosion, sounds like you have a grounding problem. Usually when the key sign shows, you have a key fob battery on its last legs (close to being dead).
Old Jan 10, 2025 | 01:30 AM
gace313's Avatar
2007 Infiniti g35x
How about for the transmission sign showing up would it also be a grounding issue
Redshock
Sep 5, 2023 07:39 PM
Lu300zxlu
Jan 22, 2019 02:45 PM
6MTG35S
May 23, 2007 04:19 AM
