Richmond/Henrico/Petersburg/Colonial Hgts G group
Rating: Thread Rating: 8 votes, 4.88 average.
Old Jan 23, 2011 | 12:57 PM
  #7156
rhampsterwha2's Avatar
Kenny you gotta keep the car looking sexy all the time man! Wash her!
Old Jan 23, 2011 | 06:43 PM
  #7157
Pheeeet821's Avatar
Originally Posted by G 30-FI
have heard of Godspeed before but mostly associated with Honda's for the most. I haven't heard of anyone running them on Infiniti's. Where did you see them advertised at?
Ebay. That's why I'm asking..
Old Jan 23, 2011 | 07:52 PM
  #7158
swordsman54's Avatar
You get what you pay for is the general rule that I follow. Also, eBay stuff is generally low quality anyway.
Old Jan 23, 2011 | 09:30 PM
  #7159
da champ's Avatar
Hey guys does some one need a set of tein s techs and tokico shocks the shocks are just for the front....
Old Jan 23, 2011 | 10:24 PM
  #7160
G 30-FI's Avatar
CLUB MODERATOR
hmmm.....as a general rule of thumb, i dont buy from ebay unless i know the product well enough to know the difference from junk and certified parts bro!! You're better off hitting up a vendor on Driver.....just my .02
Old Jan 24, 2011 | 06:49 AM
  #7161
agree
Old Jan 24, 2011 | 02:57 PM
  #7162
krocku81's Avatar
quick question.. What is the best kind of oil to get and what kind of filter? Its an 06 G35 coupe with 40156 miles. Thanks guys!
Old Jan 24, 2011 | 03:16 PM
  #7163
DOCWADE87's Avatar
You are going to find that all synthetic oils are pretty much the same these days. I am using Castrol Edge 5W-30 and like it so far. I am going to get an analysis done after 6k miles. I was using German Castrol Oil 0W-30 and it actually was found to run a lot thicker than most all 5W-30 oil. It really is up to you. Definitely use synthetic oil. For this area 5W-30 is good for your car. I have 60k on mine and it runs great and heats up in the cold pretty quick. I dont know how much knowledge you have on oil, but there is a sticky on oil on this forum that might be beneficial to you. I know several other guys use Mobil and other types but most are so close there is not that much different in brands. Hope this helps!!
Old Jan 24, 2011 | 03:53 PM
  #7164
krock, i agree with Doc 5w-30 will be fine, i use mobile 1 5w-30
the filter you can go 2 ways, go to infiniti and get it or go to walmart and use their lil computer to tell you what you need by make an model
the nissan filter comes with a new oil pan plug gasket, others will not though it is not needed
too bad you missed out on last weekend we could have done it then
Old Jan 24, 2011 | 04:54 PM
  #7165
petesg35's Avatar
Mobil 1 and nissan oil filter............
Old Jan 25, 2011 | 12:20 AM
  #7166
NJ 666's Avatar
I've taken plenty of Nissan engines apart and found that even with conventional oil changed on a regular basis the engines are clean inside. Even after 200k miles. That being said I still use Mobil 1 synthetic in my own cars. Might be a good idea for yuze gize(like the Jersey phrase) to run synthetic since the VQs are know for high oil temps.
Ryan,
Sorry I didn't have time to speak to you about the spacer you bought. That day turned a little hectic and I didn't see your posts until recently. I believe the purpose of the locktite is to seal the threads of the 6 center bolts where they go thru the plenum. The factory uses the gasket but since you use the spacers on those bolts they don't compress the gasket properly. I don't think this would be a significant vacuum leak if you didn't seal them but some of our A/F ratio sensors can be a little sensitive. Sorry to be so long winded.
Old Jan 25, 2011 | 06:37 AM
  #7167
no it makes total sense, i didnt even have some of the hardware thanks to the guy i got it from....but i ordered the hardware kit from motordyne it comes with locktite lol
i will get with you on it soon as well i need to take a look at my exhaust its buzzing on something may need to adjust it and re-torque the bolts would be real easy on a lift
Old Jan 25, 2011 | 06:30 PM
  #7168
G 30-FI's Avatar
CLUB MODERATOR
just posted this on the NGC threads, please have a look and opinions welcomed
https://g35driver.com/forums/nationa...ew-shirts.html
Old Jan 26, 2011 | 04:48 PM
  #7169
G 30-FI's Avatar
CLUB MODERATOR
ok guys, the post for the Pit Crew Shirts has been revamped and a poll is set in place.....please vote!!
Old Jan 26, 2011 | 07:58 PM
  #7170
Spade's Avatar
Ok so 2nd time I've seen this G around, it appears to be a pre 05 OB coupe, clear corners VA plates read XTY-1741. 1st time was at bar down here by me 2nd time today was about 845 in I95 just before the Chippenham exit. Stock rims and clear corners, trunk is debadged with 350GT emblems on it ON THE LEFT SIDE OF THE TRUNK???? Let me know if you any of you know who this is.
You have already rated this thread Rating: Thread Rating: 8 votes, 4.88 average.
