Changed out old spark plugs...
Old Jan 30, 2010 | 11:19 AM
BLKG35Coupe's Avatar
Unhappy Changed out old spark plugs...
Hey guys...
Need some help. I did the DIY: spark plug change. No problem...Didn't really have to move a lot of things around. I unplugged 2 tube from the plenum, and the tube for the SAI. Changed out the plugs, reconnected everything...
Cold start up: Starts up fine...car runs like a beast
Warm start up: Doesn't stay on...car runs great after giving it some gas during start up.
Scott from Ballistic says I have a Vac leak...But I'm not really sure where my leak is coming from since I only pulled 3 tubes.
Any ideas??? Where to look for vac leak?
I couldn't get hold of the NGK plugs so I ended up getting Denzo plugs, gap the plugs at 1.1mm....(I saw that spec online somewhere)....
Please help....
Old Jan 30, 2010 | 12:50 PM
GAU-8's Avatar
Check your connection at the throttle body. Sounds like unmetered air coming in. MAF is in the main tube. If you are leaking at the TB it can stall out.
Old Feb 1, 2010 | 08:18 PM
dann1313's Avatar
you also might of cracked a tube pulling them off, same happened to me. you can hear the leak.
Old Feb 10, 2010 | 11:46 PM
Neu Era's Avatar
If that doesnt work, try swapping to NGK iridiums.
Old Feb 10, 2010 | 11:53 PM
g35man04's Avatar
CLUB MODERATOR
best advice is that there should be 2 tubes on the plenum itself. Left side which is obvious, the other is on the back of the plenum where the throttle body connects. The other 2 that are on teh throttle body are for coolant and you would know if those were off the car. Then you have the actual intake tube hose. Other than that I dont know of any other VAC Leaks....
Old Feb 10, 2010 | 11:54 PM
Neu Era's Avatar
Yeah its kind of hard to spot the coolant one till its too late, i learned that one the hard way.
Old Feb 11, 2010 | 12:01 AM
g35man04's Avatar
CLUB MODERATOR
I have learned many of times..LOL!
mtlruss
Dec 20, 2015 01:51 PM
Fire0nic3
Sep 1, 2015 12:12 PM
JoeMac
Aug 20, 2015 10:17 AM
yassy
Aug 9, 2015 07:31 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
