G35 radio harness
Old May 22, 2005 | 06:29 PM
dgomes's Avatar
G35 radio harness
I jsut bought a new DVD/Tuner for my G, but I can't seem to find anyone that sells a radio harness for my car. Anyone have any ideas on where to find one? Any help is greatly appreciated...
DG
Old May 22, 2005 | 08:22 PM
CTG35's Avatar
The G's radio harness is the same as Nissan. I used Scosche NN03 for my Avic N2 install which was ordered from cardomain.com. If you are replacing the factory radio you will also need the JDM double kit, a/c controller and mounting bracket.
Old May 23, 2005 | 01:00 AM
dgomes's Avatar
Thanks CT. I already ordered the double din install kit, but I couldn't find the harness.
Old May 23, 2005 | 01:04 AM
dgomes's Avatar
BTW, do you have any recommendations for a replacement for the factory amp? I've already added a pair of Kicker Comp 12's and amp, but the factory amp is seriously lagging and I've been told that you can't add an aftermarket radio without replacing the factory amp... is that even true?
Old May 23, 2005 | 11:08 AM
CTG35's Avatar
You can but you will need to install line output converters. Easiest way is to replace the factory amp and use the existing wiring to tap off for speakers. I used a MB quart amp to replace the factory amp which is mounted on the rear seat back.
Old May 24, 2005 | 10:55 AM
dgomes's Avatar
Did you replace your speakers with MB Quarts, too, or just the amp?
Old May 24, 2005 | 02:15 PM
CTG35's Avatar
I replaced the front speakers/tweeters with MB quarts and Infinity kappa 693.5 6x9's on the rear deck.
arora_g35
Apr 16, 2026 02:52 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
