Clear corners
Old Sep 23, 2007 | 01:54 PM
urban's Avatar
Sorry man I only have the two sets.
Old Sep 23, 2007 | 07:03 PM
accordfreak's Avatar
whoo hoo amber corners! mine are stock too
Old Sep 23, 2007 | 07:15 PM
BayAreaRefuGz's Avatar
i fly low
Originally Posted by urban
Don't worry I have another set, if you want you can have them. I just bought them from D-unit so there yours, think of this as an early Christmas gift..lol
oh right on man, good lookin out! your such a sweetie
-jeff
Old Oct 2, 2007 | 03:15 AM
sliq's Avatar
what colors are illegal to put infront of your car? i know blue is? also.. whats a nice clean white/clear bulb that will look nice with the stock lights when put in clear corners?
Old Oct 2, 2007 | 11:13 AM
Kris79's Avatar
battle froggy
are you talking bout head lights or those accent lights or the corner lights?
Old Oct 2, 2007 | 06:03 PM
sliq's Avatar
the corner markers. what colors are illegal to put in it? also.. whats a nice bright white/light blue color bulb that would look nice with jdm clear corners? or come close to the stock bulbs in our head lights. i have an 07
Old Oct 2, 2007 | 07:08 PM
Kris79's Avatar
battle froggy
only legal color is amber. i been pulled over in my stock accord for just having a white light bulb in there.
Old Oct 2, 2007 | 07:35 PM
sliq's Avatar
but its not your turning signal light. its a corner marker. only turn signals need to be amber. and its legal to have any color in the corner markers except blue... red.. etc. colors of emergency
Old Oct 2, 2007 | 07:49 PM
Kris79's Avatar
battle froggy
25950. This section applies to the color of lamps and to any
reflector exhibiting or reflecting perceptible light of 0.05 candela
or more per foot-candle of incident illumination. Unless provided
otherwise, the color of lamps and reflectors upon a vehicle shall be
as follows:
(a) The emitted light from all lamps and the reflected light from
all reflectors, visible from in front of a vehicle, shall be white or
yellow, except as follows:
(1) Rear side marker lamps required by Section 25100 may show red
to the front.
(2) The color of foglamps described in Section 24403 may be in the
color spectrum from white to yellow.
(3) An illuminating device, as permitted under Section 24255,
shall emit radiation predominantly in the infrared region of the
electromagnetic spectrum. Any incidental visible light projecting to
the front of the vehicle shall be predominantly yellow to white.
Any incidental visible light projecting to the rear of the vehicle
shall be predominantly red. Any incidental visible light from an
illuminating device, as permitted under Section 24255, shall not
resemble any other required or permitted lighting device or official
traffic control device.
(b) The emitted light from all lamps and the reflected light from
all reflectors, visible from the rear of a vehicle, shall be red
except as follows:
(1) Stoplamps on vehicles manufactured before January 1, 1979, may
show yellow to the rear.
(2) Turn signal lamps may show yellow to the rear.
(3) Front side marker lamps required by Section 25100 may show
yellow to the rear.
(4) Backup lamps shall show white to the rear.
(5) The rearward facing portion of a front-mounted double-faced
turn signal lamp may show amber to the rear while the headlamps or
parking lamps are lighted, if the intensity of the light emitted is
not greater than the parking lamps and the turn signal function is
not impaired.
(6) A reflector meeting the requirements of, and installed in
accordance with, Section 24611 shall be red or white, or both.
(c) All lamps and reflectors visible from the front, sides, or
rear of a vehicle, except headlamps, may have any unlighted color,
provided the emitted light from all lamps or reflected light from all
reflectors complies with the required color. Except for backup
lamps, the entire effective projected luminous area of lamps visible
from the rear or mounted on the sides near the rear of a vehicle
shall be covered by an inner lens of the required color when the
unlighted color differs from the required emitted light color.
Taillamps, stoplamps, and turn signal lamps that are visible to the
rear may be white when unlighted on vehicles manufactured before
January 1, 1974.
25951. Any lighted lamp or device upon a motor vehicle other than
headlamps, spotlamps, signal lamps, or auxiliary driving lamps,
warning lamps which projects a beam of light of an intensity greater
than 300 candlepower shall be so directed that no part of the beam
will strike the level of the roadway at a distance of more than 75
feet from the vehicle.
25952. (a) Lamps, reflectors, and area reflectorizing material of a
type required or permitted on a vehicle may be mounted on a load
carried by the vehicle in lieu of, or in addition to, such equipment
on the vehicle. Such equipment shall be mounted on the load in a
manner that would comply with the requirements of this code and
regulations adopted pursuant to this code if the load were an
integral part of the vehicle.
(b) Lamps on vehicles carried as a load shall not be lighted
unless such lamps are mounted in accordance with subdivision (a).
btw i havnt seen a bulb that shows up pure white before, all of those little wedge bulbs come out more blue than white
Old Oct 2, 2007 | 08:02 PM
Andy2434's Avatar
LOL . . . Kris is g35 chippie's official understudy. Good job.
Old Oct 2, 2007 | 08:04 PM
Kris79's Avatar
battle froggy
haha does that mean i can shoot his ar? lol
Old Oct 2, 2007 | 08:09 PM
sliq's Avatar
so... the front corner markers may ONLY be yellow/amber and not white/clear or red or blue?
i read it, but correct me if im wrong.
Old Oct 2, 2007 | 08:19 PM
Kris79's Avatar
battle froggy
so... the corner markers may ONLY be yellow/amber and not white/clear?
white, amber, yellow since they all look the same is my guess. but it does say you can use any color lens so u can make it a blue lens and make it a white bulb lol
Old Oct 2, 2007 | 08:22 PM
sliq's Avatar
aite thanks kris. now i need to find a nice crisp white bulb thatll make my new clear corners match my head light lights. any advice on good bulbs for the corner markers?
Old Oct 2, 2007 | 08:24 PM
  #30
Kris79's Avatar
battle froggy
this is the hard part. clear bulbs come out amber yellow, blue bulbs that claim hyper white are blue. i have yet to find a bulb that comes out true white yet. i would try those led style one that claim blue. i gave a set to jdm ryan , ask him what color they came out.
