Air Bag light comes on.
Old Mar 6, 2008 | 12:55 PM
G35Papa's Avatar
Hmm. It should have worked. Are you sure you are turning the ignition to the off position before the airbag light comes on (after the initial on)? As soon as the light goes away when you turn it on, turn it to the off position immediately or the procedure won't clear the light.
Or yeah, use black tape
Old Mar 19, 2008 | 12:38 PM
mEsOaZn's Avatar
6MT VQHR Sedan
thing is that it doesnt turn off - right when u turn the ignition to ACC (turn before the engine start) it just styas solid for a 2-3 seconds then automatically start to blink on and off on and off repeatedly. Even when the car is turned on it still blinks. So yeha, any help G's? =)
Old Mar 20, 2008 | 01:35 PM
gizsf's Avatar
As far as I know, if you disconnect any of the airbag (yellow) plus and your battery isn't disconnected, that'll happen. Kinda a good thing since it's less risk of accidently popping open an airbag.. Make sure your plugs where you were working are well seated and that you didn't possibly force anything in that may have pulled the harness or wires apart first. An engine reset should take care of it, and if you need to hook up an obd-scanner, I have one (elmscan 5) you could use if your around SF anytime. If that doesn't do it....It may need to be reset by the dealer using the Consult device.
Old Mar 21, 2008 | 02:07 PM
mEsOaZn's Avatar
6MT VQHR Sedan
Yeha ama give that a try - so now i gotta re-pry everything open again and make sure everything is secure and what not. But yea if that doesnt work shoot me ur phone/contact numero so i CAN give u a call... thanks home-bro!
-Ya fellow G!
Old Mar 22, 2008 | 01:43 PM
Disco_Monkey's Avatar
When you forced it in, you may have just snagged something loose on the plug.
Old Mar 27, 2008 | 01:27 PM
mEsOaZn's Avatar
6MT VQHR Sedan
anyone know which color wire/plug this would be and where it is located at???
Old Mar 28, 2008 | 12:08 PM
gizsf's Avatar
I believe they're all yellow harness plugs. Make sure you have the battery disconnected before you start playing around with those, airbags are no joke and can jack you up real bad or even kill you! Click on the link for motivation to unplug your battery this time around...... http://ie.youtube.com/watch?v=HhBa8Xya3UA
Old Mar 28, 2008 | 12:17 PM
rookie's Avatar
I learned from caskyline. Yellow plug means caution. If you have to disconnect it disconnect battery first.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
mtlruss
Dec 20, 2015 01:51 PM
Ednica87
Sep 5, 2015 02:59 AM
Jroc2017
Aug 16, 2015 07:16 PM
Jadenkid22
Jul 14, 2015 12:33 AM
