Official NorCal G car picture share!
Old Mar 15, 2010 | 01:12 PM
  #1171
ucg35's Avatar
Ricky, stance looks dope man!
Pat, I had no idea you were on bags, I always thought you were on coils. Looks sweet!
Right on Marcus!
Pat- which kit did you go with..? im assuming UAS? fb? or fbss?
heres another flic from another thread i posted... might as well throw it in here
Im already sitting frame when fully pancaked... i want to cut the rear cups though to sit the rear lower.. i should still sit frame in the front too.
Old Mar 15, 2010 | 01:47 PM
  #1172
patman530's Avatar
Thanks again Rusty, great job with the install!
Marcus, I just picked these up right before Wekfest, and Rusty finished installing last weekend.
Also, there's no lip touch either raked or all the way down. I think the fronts are sitting at roughly about the same level regardless.
love playing with the switches
Old Mar 15, 2010 | 01:49 PM
  #1173
ucg35's Avatar
no... i mean your fender touching the lip of your wheel, or being the same level as the lip of your wheel. not bumper.
Old Mar 15, 2010 | 01:50 PM
  #1174
freshnikez's Avatar
Pat drops panties all day
Old Mar 15, 2010 | 01:55 PM
  #1175
ucg35's Avatar
its fun... you should give it a try, when your car is ready.
Old Mar 15, 2010 | 02:03 PM
  #1176
patman530's Avatar
yeah that's what i was referring to as well, i can't get low enough in front or back for the lip to touch the fender.
  #1177
freshnikez's Avatar
After playing with Pat's set up. I'm going to have to buy a set up too!
We should we rename Air Suspension to "Panty Droppers"
Old Mar 15, 2010 | 02:05 PM
  #1178
ucg35's Avatar
in the pictures its there or its close enough. what an 1/8thoff? maybe a 32nd haha its cool. nvm.
Old Mar 15, 2010 | 02:07 PM
  #1179
patman530's Avatar
Right on Marcus!
UAS, FBSS. but riding on stock shocks. I don't think I can get as low as you in the fronts. But we thought about cutting the rear cups too, but played it safe and left it for now.
Old Mar 15, 2010 | 02:21 PM
  #1180
ucg35's Avatar
im almost positve cutting the rear cups will only strengthen the integrity of the cup... you figure a take the larger of the two cups and trim that down anywhere from .5 to 1.5 inches and as the cup size decreases so does the distance from the top of the cup to the base.. walls are stronger closer to the bottom.. in theory...
i too have stock shocks and want new ones haha but 70psi in the fronts and 35psi in the rear rides cool for me.
which gauges/switches you go with?
i picked up the Easy street Autopilot kit, pretty neat.
Old Mar 15, 2010 | 02:35 PM
  #1181
patman530's Avatar
I picked up my set up from Alvin (yt35) and he already had the dakota digital and std 9 button switch. I think you're probably right about it being safe to cut the cups. I was more referring to not completely bottoming out in case of a failure with the air system. Right now at max low my car is still driveable although rubs quite a bit.
For some reason yours looks a lot lower in the front. How much did you shave off of the shock where the bag mounts?
Old Mar 15, 2010 | 02:44 PM
  #1182
ucg35's Avatar
just that ring... didint get all the way down to the shock of course but close enough to get the line to the fitting.
im also on 18's so im just lower in general.
I had a fuse blow on me while i was pancaked sitting frame...in a spot where my car needed to move.. haha that was fun driving. good thing i only needed to move it 6 feet haha. now i keep fuses in the glove box just incase.
bags are fun though ... i own driveways.
Old Mar 15, 2010 | 02:59 PM
  #1183
bigc's Avatar
Wings Nation
i want bags
Old Mar 15, 2010 | 03:00 PM
  #1184
CandlestickPark's Avatar
ill Sedan
^+1...
Old Mar 15, 2010 | 03:09 PM
  #1185
Extreme G's Avatar
Thanks Papa, I installed the coils on my car and its freaking dump right now.
