Non-Brembo Rotors?
Old Mar 16, 2009 | 01:39 PM
bert039's Avatar
Non-Brembo Rotors?
Does anyone have any recommendations on inexpensive but decent rotors? It's for a '05 Coupe Sport, the one with the dual piston calipers up front.
I was quoted a price on these OEM rotors:
$176 shipped for the front pair
$148 shipped for the rear pair.
I'm just trying to see if you guys had any suggestions on any aftermarket rotors that might be cheaper then these.
Thanks!
Old Mar 16, 2009 | 01:53 PM
bert039's Avatar
Actually I just check Beshoff's prices for the OEM ones and they look really good:
$109.48 for the front
$92.97 for the rear
Probably the shipping was raising the other price. Unless I'm reading it wrong and that's the cost for each rotor and not the pair....
Are there aftermarket rotors that you guys recommend that would be cheaper then these?
Old Mar 16, 2009 | 07:25 PM
FenixL1P's Avatar
you should try some centric rotors (made for stoptech) from carstuff.com...
use coupon code cs02 or cs03 (i forgot which, but hopefully still works) for $25 off order.
i believe they were about 75 each up front and about 55 or 60 each for the rear... better than oem...
Old Mar 17, 2009 | 12:17 AM
bert039's Avatar
Thanks! Have you bought anything from them before? I googled "car-stuff.com reviews" and the results weren't so good.
I'll look around for Centric rotors though. Are there any shops locally that sell them?
Old Mar 17, 2009 | 01:53 AM
Kris79's Avatar
battle froggy
i would do rotora thats waht alot of members are using in norcal.
Old Mar 17, 2009 | 02:18 AM
bert039's Avatar
Cool, do you sell them? Or recommend a place to get them at?
Old Mar 17, 2009 | 04:05 PM
DEMoLITIoN's Avatar
Just get OEM. Unless you track your car, you will not be needing any of that performance for DD. If you go aftermarket, avoid drilled rotors.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
