High Oil Consumption Issues
Old Jul 4, 2009 | 01:57 AM
bmpnride's Avatar
I know some of you have had some issues with high oil consumption issues. How did things work out for those who had problems? I took my car to Beshoff today and found out I was down quite a bit of oil. I am now going through the oil consumption test to see if my engine is burning more than it should. 2 qts down in 3800 miles sounds llke alot.
Stellar service from Beshoff. It was good to finally make it down and talk to Brian and see the place. I see why so many drive so far to have Beshoff take care of their G's.
Old Jul 4, 2009 | 11:33 AM
V35 Skyline GT's Avatar
6MT Coupe
Wow another non-revup going/gone South. Usually it's the revups with this issue as mine was. Quart every 1900mi is to much imo (2qt/3800)
Revups have a TSB with a OC chart (ok/no good) and how I got my replacement. Not sure what the OC standard is with non-revups.
Heard nothing but good with Beshoff, so you can prolly rest assure they 'won't' play games like sooo many dealers have and still do.
Amazing stories in those other OC threads about games played.
G/L
Old Jul 4, 2009 | 11:43 AM
bmpnride's Avatar
I have all the trust in Beshoff after talking to Brian and working with Joey in getting some issued fixed on my car. I will find out how the oil consuption liiks when I take car back after 1k miles.
Old Jul 4, 2009 | 01:39 PM
g3fly's Avatar
Joey is a good guy hes taking care of me before. 100% satisfied with work, labor, time, and coustermer servise. They did lag on a few parts but that was due to their parts supplier.
G/L with your test. Mine has the same thing but my waranty just exspierd
Old Jul 4, 2009 | 03:59 PM
frog's Avatar
ummm, 2000miles after my oil change i pulled hte dip its a little under half not sure how much that is burnt though? any ideas?
btw when i talked to a tech they said if its a stick there only allowed to do 3/4qt per 1k, and autos is 1qt per 1k
Old Jul 4, 2009 | 06:01 PM
6MT Coupe
Maybe that's standard for non revups.
Here's standard for the revups since Jan 2008.
0 to 24 #'s = oil level in mm's. 24mm = 1qt.
'no good' range = warranty replacement.
My OC was 24mm/2300mi = got replacement.
Old Jul 4, 2009 | 06:19 PM
frog's Avatar
i shold go check mine then cus tech told me other wise. since i have nothing else better to do grabs tape mesure brb! lol
Old Jul 4, 2009 | 06:32 PM
frog's Avatar
im at 17mm low @ about 2300miles
Old Jul 5, 2009 | 04:29 AM
NAT@FFTec's Avatar
ill be at beshoff on monday for my 1000 mile checkup for the OC test. i have to add about 1 qt of oil every 1k miles
Old Jul 5, 2009 | 09:54 AM
6MT Coupe
Your 2005 a 5at or 6mt?
That OC chart I posted only pertains to these G35's with 6mt's:
G/L to everyone with this OC issue be it a revup or a non revup VQ.
Old Jul 5, 2009 | 01:35 PM
bmpnride's Avatar
By my calculation, I am down 48mm for 4k miles or 12mm for 1k miles. I hope someone with non-rev up can chime in with the oil range since they seem alot different than rev-up. Also, its possible to drop a few mm within the 1001-1500 mile range so this may also change when the engine may drop into the 'no good" range. We will see next month.
Old Jul 5, 2009 | 03:08 PM
6MT Coupe
Read about some non-revup owners experiences in the main OC threads. Though most are about revups, none the less non-revs are in there too. My350 one as well. Might want to check those out. Have a 6-pack of whatever for each one, they're long and cover 'years' of this continuing issue. Wealth of info/knowledge to be had in those.
Old Jul 6, 2009 | 01:21 AM
frog's Avatar
im an 05, 6spd... WTF!! "if you confirm low engine oil OR unusual engine noise"
Ive taken my car into a few dealers for a "engine noise" and so far none of them have fixed it... "its nothing thats normal" :;3 more appts later"i dont hear nothing let us take a deeper look..day later.. theres something loose in the transmission well fix it" (still makes noise) next tech different dealer... "its the flywheel we will replace and it will fix the problem.."(fly wheel and clutch was replaced at the other dealer but ok...) nope noise still there next tech..." its the timing belt theirs spacer's inside and when they get worn down they start to knock".(wtf?).. next non certified nissan/infiniti tech, "sounds like a rod" im about to give up i keep getting different answers as if they dono wtf there talking about.... they should know my engine like the back of there hand they are certified arent they?
Old Jul 6, 2009 | 10:52 AM
bmpnride's Avatar
What noise are you hearing Frank?
Old Jul 6, 2009 | 01:19 PM
NAT@FFTec's Avatar
just had my first 1000 mile test performed at beshoff. i was down 9mm and i am approved for a new motor
