Best Tire Place - Good Prices on Tires, Mount & Balance?
Old Sep 25, 2010 | 02:09 PM
elayman's Avatar
I'm in the norcal bay area and one of my front tires has some awful inner camber wear and all of the tread is gone. Looking for 235/40/18 to replace both fronts unless it's a better idea to replace all 4 tires. Is it bad to mix brands of tires front and rear? Please let me know where I should look.
Old Sep 25, 2010 | 09:34 PM
ntrinsik's Avatar
You should be okay to mix brands between the fronts and rears. I typically go through Tirerack for my tires and have them shipped to an installer. Vex in SJ mounted and balanced my 4 tires for under $60.
Old Sep 26, 2010 | 05:42 PM
elayman's Avatar
^ Thanks. Do you know if Dunlop would offer any sort of compensation for my tire? All my other tires have slight camber wear but are perfectly fine.
Here's the deal:
I bought my tires/wheels used from a member of my350z and they had roughly 2-3k miles on them. I had the wheels on my G lowered on S-techs with an alignment for around 6-7k miles (< -2 camber) and now I have them on my z for <800 miles with an alignment barely lowered at around -1.6 camber. The inner tread is worn to shreds while the rest of the tire is perfect. I doubt I can get a warranty from the place of purchase since I don't have a receipt but what about manufacturing? Do they warrant such things?
Here's a pic:
Old Sep 27, 2010 | 01:51 AM
bmpnride's Avatar
Discount/Americas tires in redwood city. They will price match anything you see online and offer great warranty on tires.
Old Sep 27, 2010 | 03:05 AM
DivZero's Avatar
What are your TOE specs?
Old Sep 27, 2010 | 03:25 PM
elayman's Avatar
Toe is at the spec. I forget it's like 0.5 or 1.0 or something?
Old Sep 27, 2010 | 04:45 PM
TORETTO's Avatar
I had my tires installed at The Shop right behind Tanforan Mall. They work on some "hellaflush" cars so I trusted them.
Old Sep 27, 2010 | 04:56 PM
ntrinsik's Avatar
The Shop does good work. Usually around $20/tire I think as well.
If your toe is .5 or 1.0, you definitely need that fixed. I doubt you'll get anything from the manufacturer. I think mine is 1/32nd or 1/16th (total) on the rear and 0 in the front.
Old Sep 27, 2010 | 05:20 PM
elayman's Avatar
Oh maybe it was 0.5 when I brought it in and around 0 when I left. oops
Old Sep 27, 2010 | 05:42 PM
NAT@FFTec's Avatar
Dunlop will not warranty that tire. That tire is obviously worn due to alignment issues
Old Sep 27, 2010 | 05:46 PM
calcul8's Avatar
I can haz potato?
sabertooth tiger
I've had good luck with Faxon Garage - they've always treated me and my car well
Old Sep 27, 2010 | 06:28 PM
TORETTO's Avatar
Faxon Garage is good too. Theyre driveway is just a little steep for me.
Old Sep 27, 2010 | 06:30 PM
elayman's Avatar
Thanks guys I'll check out a couple of places. Figured it was alignment issue but thought it was strange that only 1 side would do that when the other side has at least 5 more mm of tread on that same tread line
Old Sep 27, 2010 | 06:33 PM
calcul8's Avatar
I can haz potato?
sabertooth tiger
That's what their ramps are for
If in doubt, let them drive your car onto the ramps
Old Sep 27, 2010 | 06:34 PM
TORETTO's Avatar
They have ramps? Last time I went there, they didn't use jack! And I had to listen to my front bumper and Y-Pipe scream for help.
