Would anyone like to help me out? :x
Old Oct 25, 2010 | 02:19 AM
willcho415's Avatar
I've been going crazy with my sticky clutch problem. Ive been buying brake fluid every 2 months since im always refilling my clutch fluid reservoir with new clutch fluid. People said its most likely my master or slave cylinder but i would rather try doing the other methods to see if that fixes my problems.
Basically, I want someone to bleed my clutch fluid and help regrease the clutch pedal actuator shaft. If anyone is willing to do it for me, I can pay you or give you whatever you want (thats reasonable of course)
there are days when im stuck at the red light because i cant shift into gear so I have to turn on my emergency lights and go fill in more clutch fluid.
Old Oct 25, 2010 | 02:24 AM
SE5spd's Avatar
Sure it's not a bad slave cylinder?
Old Oct 25, 2010 | 02:29 AM
willcho415's Avatar
i have no idea...i had shops tell me itll cost around 80-120$ to find out which part of the car is causing the problem -_-
Old Oct 25, 2010 | 02:45 AM
willcho415's Avatar
oh and BTW i dont know if this helps identifying my problem but when my car starts up cold, itll have sticky pedal FOR SURE until it warms up. Also, one of my belts (my ac belt i believe) screeches when the car is cold. When I engage the clutch in gear and let the clutch go, the screeching goes away after a few seconds.
Old Oct 25, 2010 | 09:01 AM
SE5spd's Avatar
When my slave cylinder went out, the clutch would stick to the floor and I'd stick my foot under the clutch and raise it again, what yr is your G?
Old Oct 25, 2010 | 02:17 PM
lsmooth81's Avatar
Since you are in the Bay area PM BYTHEBAY he is very knowledgeable and will help you out. Or you could check out his DIY videos, I think he has one on Bleeding/Flush Clutch Fluid. Good luck
https://g35driver.com/forums/g35-sed...eo-series.html
Old Oct 25, 2010 | 03:35 PM
willcho415's Avatar
SE5spd my g is a 2004
lsmooth81 Thanks a lot! I watched the bleeding/flush clutch fluid. The problem is, my car is really low and i dont know how im going to find that screw lol. Also, i dont have anymore tools.. but ill PM bythebay and see what i can find out =]
