NorthWest Serving AK, ID, OR, WA
need helppp near sammamish
Old Sep 22, 2006 | 08:12 PM
cchaorule's Avatar
hmm.. i just got the stillen intake/ztube.. anyone that live around sammamish, washington want to help?? it will be greatly appreciated =)
Old Sep 22, 2006 | 08:27 PM
g35cas's Avatar
That's a simple bolt on. Just read the Stillen instructions. If you still can't figure it out, there is a multi car meet on Oct. 1st(Mt.Vernon), I can meet you there. Or you can come up to Bellingham and I can knock it out in about a half hour. By the way, I have the same set up. Don't worry about the bolt in the bottom of the heat shroud, it's a biotch to get in and out when cleaning filter. I put some foam padding underneath the heat shroud to protect the A/C lines.
Old Sep 22, 2006 | 08:34 PM
cchaorule's Avatar
cool man.. is there any quick tips before installing? also do i need to reset the ecu? if so how?
Old Sep 23, 2006 | 12:20 PM
g35cas's Avatar
Becarefull about hanging on to your tools. It's a biotch to retreive tools that fall onto the underbody plastic cover. Search for the reset, there is about 200 posts on it, or you can disconnect the battery for a night. Good luck.
speedcretin
Aug 20, 2013 01:37 PM
Versus
NorthWest
41
Sep 11, 2006 09:02 PM
cchaorule
NorthWest
Jul 30, 2006 10:29 PM
Triple8Sol
NorthWest
Sep 20, 2005 12:15 AM
