NorthWest Serving AK, ID, OR, WA
Local shop to install window motor?
Old Mar 16, 2007 | 04:23 AM
Jining's Avatar
Hello, my passenger side window motor is dead and infiniti quoted me 550 to replace it... 350 for the motor itself, which I found for 170 new online.... just curious if anyone had suggestion of a place to take it. I heard gregs japanese auto is good, let me know! Thanks a lot!
Old Mar 16, 2007 | 04:46 PM
Drewer's Avatar
Do it yourself for free! There's more than enough resources on here and it is a fairly easy job.
Old Mar 16, 2007 | 05:16 PM
Jining's Avatar
Hmm i was thinking that but no I couldnt find anyone that has done it themselves. I found the g35 service manual and it doesnt look too hard.... have you done it? If so, do you know if I need to remove the window to do it?
Old Mar 16, 2007 | 06:46 PM
Drewer's Avatar
I've done it on a E36 BMW 318i and an OLD Volvo 740 turbo. The glass usually sits in a tray the has scissor arms that attach to the motor and door. I'm not sure about our cars, but for those other two I didn't take the window out at all. Just pulled the door panel with the window up, removed the old motor, lined up the new one, and bolted it in. Does the service manual online here (from heatsinkninja) have a good exploded view of the door, and/or say that the glass needs to be removed?
-andrew
Old Mar 16, 2007 | 09:59 PM
Jining's Avatar
Well, I do have the exploded view diagram but it really does not say anything about removing the window, it just says to raise the window up, and then unbolt it from the arms, and then pull up the back... so im not sure if pull up the back just means extend it up as far as it will go, or if that means it will come off the door
hdmark
Apr 29, 2019 04:31 PM
will091195
Jul 27, 2015 09:19 PM
jimNC
Jul 25, 2015 05:47 AM
Kal Hamm
Jul 24, 2015 08:55 AM
justgotg35
Jul 19, 2015 12:33 PM
