NorthWest Serving AK, ID, OR, WA
OEM Brembo Pads replacements needing help
Old May 11, 2007 | 03:46 AM
SkyG35's Avatar
Just got Brembo slotted with HAWK HPS pads. Does it require any special tools to get the pads off?
Thanks
Old May 11, 2007 | 10:10 AM
redlude97's Avatar
pads take like 5 mins once the wheels are off.
Old May 11, 2007 | 12:51 PM
Triple8Sol's Avatar
There is a special tool top push back the pistons, but you can substitute something else. Since you're replacing rotors too, you'll be removing the calipers anyways.
Old May 11, 2007 | 02:07 PM
SkyG35's Avatar
Ok Thought someone had told me you need special tools to get the Brembo pads off and on. Thanks for the help guys.
Old May 11, 2007 | 02:11 PM
madchef's Avatar
Nope, once you compress the pistons (watch that fluid level!) outside pad is floating, inside you just pull off the spring clip (easy)
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
vstypicals
Jul 20, 2015 10:55 PM
mushu
Jul 15, 2015 03:55 PM
