NorthWest Serving AK, ID, OR, WA
My APS TT and CJM Stage2 Self Install
Old Aug 16, 2007 | 02:52 PM
Jining's Avatar
Thanks guys! It really is not bad leaving the motor in the car by the way so if you guys are thinking of attempting it, theres no need to pull the motor, just unbolt the motor mounts and jack up the engine a few inches.
Old Aug 16, 2007 | 03:53 PM
Triple8Sol's Avatar
Originally Posted by Jining
Exhaust is invidia g200... i need to upgrade to 2.5"
Cheaper for locals like yourself: https://g35driver.com/forums/questionable-posts/169490-fs-brand-new-topspeed-pro-1-exhaust.html
Old Aug 16, 2007 | 03:59 PM
Jining's Avatar
Oh I meant dual 2.5", the n1 is single 2.5 right? Invidia g200 has better flow, 2 x 2" vs 1 x 2.5"
Old Aug 16, 2007 | 04:41 PM
Triple8Sol's Avatar
Oh, gotcha. Yeah, the Topspeed is a single 2.5" that splits into dual N1-style mufflers. They also have a 3" version, but it is out of stock until mid/end of September.
Old Aug 16, 2007 | 04:45 PM
Jining's Avatar
ah, thanks anyways man
Old Aug 22, 2007 | 06:14 AM
Jining's Avatar
Well after a long grueling ordeal involving an oil leak upon completion and then a broken special 12mm wrench that was provided with the kit...it is finally running without leaks.
:0) Gonna double check there no leaks tommorow morning (wednesday) and then its off to the tuner!!
So relieved to get this done
Old Aug 24, 2007 | 08:17 PM
Jining's Avatar
Well another update: Car is holding 8Ib Boost. Slight exhaust leak on LHS but other then that its preeeeetty nice
Old Aug 24, 2007 | 08:22 PM
Jeff92se's Avatar
Red Card Crew
Wow congrats. Props for the self install!
Old Aug 25, 2007 | 04:31 PM
ukgt's Avatar
Could you post a DIY on your total fuel line/pump upgrade with some pictures would be good.
Did you hit any problems with this part of the install prior to fitting the TT kit.
Old Aug 25, 2007 | 04:39 PM
Jining's Avatar
Ah I should have thought of that as I did it.. a bit hard to do it now.. the CJM site has some instructions that are pretty easy to follow, not exactly detailed but you can figure it out for the most part. Their site is down or I would give you the link.
Old Aug 25, 2007 | 08:30 PM
Rsim35's Avatar
Congrats on getting the install done yourself. Post some pics up asap!
Old Aug 25, 2007 | 08:34 PM
Jining's Avatar
Whats up Roy. Will do.
R350k5
Oct 1, 2015 08:41 PM
gatorglaze
Sep 10, 2015 12:03 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
