Springs G35 questions
You DO NOT want the G version of Tein S Techs. The rear spring rates are way too low. If you're not looking for too much drop, you might want to go with the Z version of the Tein H Techs.
I have a ton of wood in my trunk for my subs etc, so your saying it would sag Pat? if i bought g35 version.
Sorry im a noob at buying springs, im not used to so many choices.
Pat if i get the 350z htech it wont sag right? I have about a 3inch gap on all wheels currently. im looking for 1-2ish gap.
Any spring over 0.8" drop will need a Camber kit. Just get some that will give you a drop of 1" and get a Camber kit later. You could also just flip the tires every 4,000 miles and save the $$
Yes be careful of the spring rates, if you have Sport Tuned package and you get the G35 springs you will have a softer suspention. That's why I got Linier 350Z springs on mine...
Yeah I have the sport package. What are Linier 350z springs?
If i get coilovers will i need a camber kit?
Some tein basic coilovers are like 6-700 and springs are 200 plus camber kit so its pretty close....
I have tein basics and don't have a camber kit. I'm on the lowest setting. I even had s techs with a cut coil that made it to where I was the lowest g on the planet lol I just had my tow adjust as positive as it could go. Les schwab did it for me.
I have yet to install a camber kit, Les Schwab did my alignment and I am off in the front, but rears are within OEM specs. So far my tires are ok, but I will end up flipping them soon just in case!
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
