NorthWest Serving AK, ID, OR, WA
Lowering Question?
Old Jan 24, 2005 | 12:55 PM
The_Driver's Avatar
Lowering Question?
I'm looking to lower my 03 Sedan w/sport suspension and would like to know who has lowered theirs, what setup you have, and how is the ride/appearance? I'm not looking for a major drop (enough to stay within spec) and would not like to loose any ride quality. Also where is a good place to do the work in the Seattle area?
thanks
Old Feb 3, 2005 | 06:30 PM
g35cas's Avatar
lowering
If you can find some stock 350z springs, this will drop you about an inch with the same ride quality(same spring rate as the coupes, but I'm not quite sure about your sedan sport springs). You should have no problem with alignment, and any shop would be able to do an install for under $200. I have 350z springs installed on my coupe($50 on ebay), it dropped me 1/2 in. and only cost me $160 to install at les schwabb.
Old Feb 4, 2005 | 04:45 PM
The_Driver's Avatar
Thanks for the reply....I went with the Tein H-Techs....should be here next week.
rezendvous420
May 31, 2020 01:26 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
