FS: Modded PSP v.3.91M33 w/ 4gb pro duo
I havent played with it as much as I would have liked.. so I'm hoping someone will put it to better use. Its a modded fat PSP, v.3.91-M33, allowing you to play PSP games and emulators (NES, SNES, Sega, Arcade boards like the CPS-2 which I'm including, etc.) it comes with a 4gb pro duo, charger, battery, and USB cable. I will include games if you want, but use at your own risk. I finished Final Fantasy 7: crisis core and now occasionally playing Marvel vs. Capcom.. sparingly, which is a waste. Now for the bad: a few scratches from everyday usage... not bad.. LCD screen works perfectly fine.. the battery compartment seems a little loose (cover), so it may shut down if you shake it too much, dunno if its the battery's fault or the cover.. but if you keep the ac adapter on, you will have zero problems.. also try buying a new battery or battery cover if you like.. I GUARANTEE you everything works fine and it will not crash or freeze on you. Looking for a MEASLY 180 picked up or 190 shipped, here are the pics:
