FS[NorEast]: DHS Supreme Pro Ping Pong Table & Ping Pong NJ Robot
Old Dec 12, 2009 | 08:56 AM
xjonmo's Avatar
LOCAL ONLY. WILL DELIVER. NO SHIPPING!
I have (2) DHS Supreme Pro Ping Pong Tables. Both are BNIB.
Company: DHS (Double Happiness)
Model No: T1223.
This is a competition table, as seen in the Olympics and other competitions.
DHS Supreme Pro T1223 Ping Pong Table - The most widely used DHS table in important international competitions! The DHS Supreme Pro goes from from box to play in just minutes! Comes with a 1" edge banded top, 2" square steel legs, 2" x 1" steel support apron, 4" casters with ball bearings and brakes, height adjustment devices on outside legs, corner protection
pads and fold-up storage position.
* ITTF (Int'l Table Tennis Federation) Approved !
* USATT (US Table Tennis Association) Approved !
DHS Supreme Pro Table Tennis Features :
Color of Top: Blue
22mm Tournament Edge Banded Top
2” Square Steel Legs
2” x 1” Steel Support Apron
4” Casters with Ball Bearings and Brakes
Height Adjustment Devices on Outside Legs
Fold-up and storage position
Comes with Posts & Net
DHS Supreme Pro Open Table Tennis Dimensions :
Length: 108", Width: 61", Height: 30", Weight: 340 Lbs
Info from: http://www.bmigaming.com/games-sports-pingpong.htm
Retail: $1100+
Looking to get $900 OBO delivered within a reasonable distance otherwise buyer will be responsible for pick up. Tables are located in Bergen County, NJ
Picture is of half of my personal table in my basement. Other half was on the other side of the room and I didn't feel like moving things to get to it. Yours is BNIB
I also (3) Ping Pong Robots for training or just playing regularly by yourself.
Company: Y&T
Model No: V-988
Maximum ball frequency: 90 ***** per minute
Minimum ball frequency: 30 ***** per minute
Maximum ball speed: 35m/sec
Minimum ball speed: 4m/sec
Ball capacity (40mm *****): 50 to 145
Ball spins: Light to heavy topspin, backspin, sidespin, and no-spin
Oscillation range: angle from 0 to 40 degree
Serve style: Programmable mode for 2 position on whole table
Recycling Net: Yes
Material: aluminum alloyhigh-quality steel; ABS plastic
Automatically collect and return *****: Yes
Function of ball counter: select how many shots after you want it stop;up to 999
G. W. :21 kg
N. W. :13 kg
Machine body dimensions: 52*37*105cm
Package dimensions: 107.5*55.5*51cm
Power supply(spec of transformer)
Input: 220V-240V 50Hz 48W; For 110V,it requires a 100W or 200W Voltage Transformers to step it from 110V to 220V
Retail: $1000+ and you cannot find this anywhere
$700 each delivered within a reasonable distance
Pictured robot is my personal one. You will get one BNIB
Will include 50 ***** with each purchase IF i can find them. I have a whole box in my basement somewhere
$1300 if you buy both!
Attached Thumbnails DHS Supreme Pro Ping Pong Table & Ping Pong NJ Robot-c97e572c77c1209bacc99bfa69f6c067.jpg   DHS Supreme Pro Ping Pong Table & Ping Pong NJ Robot-1212090816.jpg   DHS Supreme Pro Ping Pong Table & Ping Pong NJ Robot-1212090817.jpg   DHS Supreme Pro Ping Pong Table & Ping Pong NJ Robot-1212090818.jpg   DHS Supreme Pro Ping Pong Table & Ping Pong NJ Robot-1212090818a.jpg
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
